Question about Dewalt Saws
New (unused) DeWalt dcs331 cordless jigsaw releases blades after a few moments of sawing thin aluminum. Blade seems to engage and lock properly after inserting, but won't hold when sawing begins.
  • 380 Answers
Which blade are you using? You need a blade with a lot of teeth per inch to cut any thin metal.
Posted on Feb 02, 2019
  • Tom Altman
    Tom Altman Feb 03, 2019
    Good tip, thanks!
4 Suggested Answers
SOURCE:
SOURCE: dewalt recipr. saw keyless chuck tab used to
We had to send our saw to repair center to install new lever. Fortunately, still under warranty.
Posted on Aug 10, 2009
Fix4You
  • 32 Answers
SOURCE: How do I replace the
Using the following link, you can enter your product model number in the Find Parts field and download the manual in PDF format. Information for the DC330K is on page 2 of its manual, if that's the model you have.
http://servicenet.dewalt.com/
Posted on Dec 07, 2010
  • 5 Answers
SOURCE: New dewalt dw716 compound mitre saw blade won't
over heating
Posted on Oct 25, 2014
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
I have a milwaukee jig saw, 6268-21 that I cannot load blades.
Yes the Milwaukee 6268-21 does require the use of certain jigsaw blades. You have to use T-shank type blades. You push the tension lever hold it while putting the blade in as far as it will go, then you release the tension lever slowly and it will engage the blade. You should then check by pulling on the blade to make sure it is seated properly and will not come out.
Oct 20, 2009 | Milwaukee Tool Milwaukee Orbital Jig Saw...
My cordless jigsaw doesnt seem to give out as much power anymore and its not the batteries
The commutator on the motor is probably dirty. Use a light grade sand paper and turn the motor by hand while you clean it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 24, 2009 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
Blade comes out while sawing
I have used the same tool. Make sure that the blade release/ hold tab is engaged. Maybe the return spring is fouled or stuck. Try some lubricant.
Jun 20, 2009 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
Jig Saws safety problems
look out for the following safety features: * Safety switch or lock off button * Some saws have a soft start feature that starts the saw at a slower speed. * Blade guard that shields you during use
Aug 27, 2008 | Dewalt DC6KTJA 18v. Xrp Super 6 - Kit...
Saws Logo
71 people viewed this question
Top Dewalt Saws Experts
mikenearman
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
