Question about Microwave Ovens
Hello Hi i just bought e brand new delonghi microwave oven mwj63 and i have a problem.As soon as i close the dorr the fan of the oven starts and the plates is spining and i cannot stop this or i cannot start to make him work. please i realy neeed help Thanks.Regards Constantin
  • Microwave Ovens Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
It may have been damaged in shipping.
In an oven that's not new, this can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
Since it's under warranty and very new, I would take it back to the dealer for a new one.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
Hello I have a delonghi combi microwave and every time I switch it on at the mains it switches on for about a second and then trips the fuse in main fuse box
There is a short in the primary electrical circuit.
A microwave technician will need to open the housing to check.
The actual location of the fault can vary widely, ranging from water / moisture causing a short, wires burnt or touching, fan motor cooked, control board fault, a loose live connector floating, lamp holder fault, etc.
Jun 20, 2017 | DeLonghi Microwave Ovens
I have a microwave oven over the range ,brand Frigidaire , model CFMV156DC purchased in 2006 and stopped working , even the lights on the front panel are on when I press the start button it happened just a...
I have exactly the same problem. Everything works perfectly even fan, except microwave table won't turn. I just found out what's the problem... The door for some reason is sitting too low now, even though it is not obvious at all. It looks leveled with everything else, but it's not. Set your Microwave to let's say 30 seconds and turn it on. It will not do anything... but you just gently lift the door (while closed of course) few millimeters and your Microwave will start running like new. There is something wrong with those latches on the door, not touching the microswitches inside the Microwave. Doors must be properly closed in order for Microwave to work. This is due to poorly design. I yet have to figure out how to fix that permanently.
Apr 15, 2011 | Frigidaire FMV156DC Microwave Oven
Hi, i have an ac925efy delonghi microwave oven, i bought it manufacturer refurbished and when i switched it on there was a big bang and a flash. it came from what looked to be the back top right hand...
From your description it is the magnetron that heats the food that has gone, I suggest that you take it back for a refund, because if you decide to fix it the repairs will run you more than what the microwave oven is worth.
Jan 16, 2011 | DeLonghi MW 535 Microwave Oven
Brand new and door does not seem to close right . when it does close I can not get the microwave to run
door switch is bad...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Dec 27, 2010 | Magic Chef MCD990W Microwave Oven
Our Microwave keeps running unless we give it a whack!
Hi firstly to see if it is producing energy, buy some 5mm light emitting diodes from an electronics store. cut off the leads close to the plastic body.
place in microwave and put on cook for max 10 secs, if the led's light up you have microwave energy, shut off the oven as soon as they glow otherwise you end up with a mess.
If you have energy then your problem is most probably the door interlock micro switches which after time do not operate properly. let me know the results and we can go further.
Feb 23, 2009 | Danby DMW1153 Microwave Oven
Turntable won't stop
Sounds like a door switch problem or stuck relay contacts on the control PCB. Do the light and fan run too or just the T/T??
Nov 07, 2008 | Jenn-Air JMC9158AA Convection Microwave...
GE Microwave Model JES735
Yes, the fan blade is hitting something inside.Usually by opening the microwave, you can slide or reposition the plastic fan blade on the shaft.Probably this happened in shipping to the store where you bought it.CAUTON:make sure the unit is unplugged before you attempt this.Other option is return for replacement.
Nov 06, 2007 | GE JVM1630 Microwave Oven
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
