Start by getting a program called SIW from Gabriel Topala's website. Once you install this, under hardware and audio or sound devices, you find all brand and part specific info to give further information.
Also try under audio devices in control panel, check which device is set to default, and tinker with it, if you change it to a new option and you hear a "BING" you have fixed it. NOTE: Write down the original setting so you can put it back if you dont fix it.
If you need further help let me know, I CAN solve this problem.
Jim
If your computer came with a motherboard disc the sound drivers could be on it
Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable Hope this helps.
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then
You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
Make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
