Question about Creative Labs MuVo V200 MP3 Player
It says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error?? It says File system error when I turn it on and then it turns itself
  • 6 more comments
  • chrisbrown Nov 28, 2007
    it turns on and says file sytem error
  • Anonymous Dec 03, 2007
    it says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error??
  • rohit8040 Jan 09, 2008
  • Leo77 Jan 31, 2008
    same thing, it says file system error and shuts off. Please help.
  • margrette Mar 17, 2008
    everytime i turn it on it automatically shut down,how can i fix this error?
  • steven danie Dec 29, 2008
    its the same
  • cravin morrehead Mar 12, 2009
    same with mine
  • Anonymous Apr 28, 2009
    the same
Posted on Dec 03, 2007
3 Suggested Answers
SOURCE:
SOURCE: It says File System Error
Had the same problem, but could not reformat, until I read elsewhere on the net that you should not format using FAT32, but just select FAT16 or FAT, it worked with my XP pc.
Posted on Jun 14, 2007
SOURCE: fill system error in muvo v 200 usb
i have an problem as i/o errror be connecting with usb port
Posted on Jan 21, 2008
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
Philips gogear 8gb mp3 file system error
m8 that happens to minebut i cant fiqure it out
Oct 22, 2011 | Philips GOGEAR SA6045 MP3 Player
I get an error msg when i try to open a thumbnail pic
what is the error message?
most common fix for thumbnail issues is to delete the Thumbs.db file in the folder
note this is a hidden system file if you dont see this file let me know and i will provide instructions on how to view it.
this file will automatically be recreated the next time you open this folder
Dec 29, 2010 | Computers & Internet
System defaults to "Automatically fix file system errors"
Open my computer and right click on your local drive click properties click tools click check now remove check from Automatic fix file system errors start same with the more drives
Jul 04, 2010 | Sony Computers & Internet
File System Error
You'll need a computer with Windows XP... with the Philips GoGear Vibe Device Manager running, plug your player holding down the volume button "+"... Just wait and it will fix it automatically. ;)
Feb 04, 2010 | Coby MP-610 MP3 Player
Error code 80029c4a quickbooks easystart 2010
This should help.. restart and then follow this..
To resolve this error, try restarting the computer that hosts the company file:
  1. Click the Microsoft Windows Start button and select Shut Down. The Shut Down window opens.
  2. Click the drop-down arrow and select Restart, and then click OK.
  3. Open Quickbooks and try to open the company file.
If the error continues, ensure that any firewall and/or antivirus software is configured to allow access to the QuickBooks company file and folder.
Jan 05, 2010 | Computers & Internet
File system error: FAT is corrupted
Your hard disk on your media player is corrupted which also does happen on a normal PC/Laptop. To fix it, use windows explorer -> right click on your mouse againt the media player drive -> select properties -> select 'Tools' tab -> select Error checking / Check now -> Tick on 'automatically fix file system errors and recommended also 'scan for and attempt recovery of bad sectors' -> Start.
At this point, you may also need to restart your PC/LAPTOP and then be patient as 120GB is a fairly large drive to repair! Once the FAT has been repaired, depending on the corruptions, you may need to replace some songs, video, photos or other files.
ps. the other 'drastic' option is of course to reformat the whole Media driver drive !!!
Dec 18, 2009 | Archos 5 MP3 Player
Windows error code, my computer starts up gets to windows sign in screen you sign in and it turns back off. when I press the F5 key and try to boot from hard disk cd-rom or the other option it wont let me...
Please tap F8 continuously as the machine first boots up
Choose safe mode from the menu
Then click on start and all programs
Click on accessories and then system tools
Click on system restore and choose an earlier time
Choose a date before this started
Sep 07, 2009 | Computers & Internet
My problem is I have a printer and I cannot install it because the file wiafdrv.dll on windowsxp home editon cd-rom is needed an do not have one.
Do you have a Lexmark printer? I found this dll file and many of the comments about it relate to Lexmark printer issues. Click the below link and it will download your missing dll file. I searched for "wiafdrv.dll" and there were no hits for this dll, but there was one for the dll file "wiafbdrv.dll". Make sure before clicking the link below, that this is the correctly named dll file you need.
http://www.dll-files.com/dllindex/wiafbdrv.zip?0VFiP0aMgO
Extract this file and place the dll file in the correct location as specified by the error you're receiving.
Mar 04, 2009 | Computers & Internet
Creative Labs MuVo V200 MP3 Player Logo
2,413 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
