Question about Canon imageRUNNER 2000 Copier
Error reads: Check Printer CoverThere aren't any jammed sheets. We have tried restarting. There doesn't seem to be anything amiss, and yet we still get this message.
  • 2 more comments
  • tash24 Nov 27, 2007
    We think it is one of the sensors that has gone bad. We had to call the repairman. Thanks for telling us.
  • Anonymous Dec 10, 2008
    my CANON printer says to ck printer cover. there is nothing wrong that I can find. It was working fine one minute and then the next I had an error. How can if fix
  • mohsin_aezaz Apr 15, 2009
    cheack printer cover problem again and again coming
  • kalyan deepak Oct 13, 2012
    canon photocopy machine ir 2016 show check document
  • 109 Answers
Check Printer Cover in CANON Ir 2010
Posted on Oct 01, 2008
  • 86 Answers
I know what the problem is phone 07764303923
Posted on Feb 14, 2008
  • 42 Answers
Check paper path ad the sensors, sometime i find a small piece of paper jamm the sensors, and the sensors thik is a problem, if the sensors are clean, then a sensor is busted,
Let me know that fix ur problem
Posted on Nov 26, 2007
What is wrong with my printer
I get this many times but I always see the paper jammed when I open it up. Once I removed the sheet which seems to stop at the transfer roller, I restart but it sometimes happens again.
One has to check the paper in the tray and see if it is free inside the top of the tray.I move the pickup.
Have you turned it off for a few mins then on again. Tried different paper?
Good luck
Jul 17, 2014 | Xerox Phaser 6250 Laser Printer
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I keep getting a carriage jam error message. There doesn't appear to be a jam, but I am unable to clear the message and print anything. Also the display screen reads original loaded. No idea what this...
Check the location of the ink carriage. If a piece of paper gets wadded up under this or something else is obstucting it you will see this error.
The original loaded message comes up when a sheet of paper is in the scanner tray.
Apr 01, 2011 | HP Officejet 7210 All-In-One InkJet...
Epson Aculaser CX11N /11NF. Paper jam error will...
this could be due to the sensor at behind of the printer.. you should be able to see it once you open cover E.. it's very delicate plastic and normally when you clear the paper , you might accidently damage it.. you will need to open the read feed assy to fix it.. 4 screws and you should be able to remove it.. but first remove the E cover but slightly forcing the lower left hidge.. use a test pen...
May 20, 2010 | Office Equipment & Supplies
My Lexmark C510 printer will print one sheet fine and then give me an error, "201 Paper Jam, Open Rear Door". If I turn the printer off it will reset and I can print one sheet again and will get the same...
there is small Plastic sensor on the paper path, is stucked or broken, is giving this error, need to look closer and check if anything is stucked (paper or dust)
Dec 28, 2009 | Lexmark C510n Laser Printer
Error paper jam
You should go to the website of whoever manufactures your printer. They always have drivers for their printers that you should be able to download and install in just a few minutes.
If you're absolutely, 100% sure that there is no paper jam, I would recommend just unplugging and restarting the printer.
Also, it may read a paper jam if you insert too much paper at one time. If you have a lot of paper installed in the printer, try taking out all but 10 sheets, and retry printing. My printer has a tray that accepts 150 sheets, but it "jams" if you put even close to that many in.
You should make sure that you aren't putting the paper too far in as well. Try pulling it back a few millimeters, as it may read a jam if the paper is pushed into the printing area.
Jun 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper tray feed problem
the shaft the roller is on is bent or the clutch on the left of the shaft iis broken.
Jan 02, 2009 | Samsung ML 1510 Laser Printer
CANON ir2000
All of the doors a closed right? I had the same problem with a IR-2000. It has to do with the cover on the left side of the copier. The door that has the drum in it. Make sure the drum is installed correctly. There is a small switch on the back of the copier that gets actcuated by the rear or left arm that is attached to the door. I fixed it by taking that door out and look at the end of the shaft/white arm and look for a worn out area toward the end and if so wrap some tape around that end to reform it and reinstall and that should do it for you. If not you may have a bad switch. It had me going for awhile, but I found it...
Sep 29, 2008 | Office Equipment & Supplies
Paper jam
Pull out power cable and, disconnect priter from power outlet, put cable back in.
If you still have led on after this, open all doors and check again fo intrusion. Pull out paper tray and check that there isnt a paper sheet stuck underneat the printer.
Open front door, pull out toner and chech under toner, put toner back , restart and try.
Open back door and check if there is a second paper sheet stuck inside
regards.
Mar 21, 2008 | Samsung ML-2550 Laser Printer
Canon imageRUNNER 2000 Copier Logo
238 people viewed this question
old marine
old marine
