Question about Olympus FE-190 Digital Camera
No flash fe-190
All of the sudden I can't get the flash on my camera to turn on at all. Everything else seems to be working fine.
  • 4 more comments
  • dummykam Dec 03, 2007
    I've the same problem started from yesterday in a X'mas bunch party. The Flashlight just flash intermittentely even I set it to Fill-in mode to force the Flashlight on.
    I've do the default reset but no helps.
  • Anonymous Oct 23, 2008
    The camera works great, the flash will not work at all. I have tryed everything and it will not flash for a picture and it wont turn on permently either.
  • a_krausie Nov 07, 2008
    I have the same camera with the exact same problem, what did you guys do to fix it?
  • jenlap Nov 30, 2008
    My flash does not work :(
  • robwayn Jan 12, 2009
    Camera will only work with the flash turned off
    I need help bad
  • Anonymous Mar 25, 2009
    my camara will not flash even wen the flash is on
I have the same problem. I dont know how to get it to work.
Posted on Apr 16, 2008
How do I turn off the flash on my Olympus FE-190?
Press cursor-right (marked with a lightning bolt), then select the desired flash mode. To turn the flash off, select the lightning bolt in a circle with a slash through it.
Full details are on page 17 of the Advanced Manual. If you need a manual, you may download a copy from here.
Dec 22, 2012 | Olympus FE-190 Digital Camera
The flash does not work even if the flash setting is SET to FILL ( the flash will work every time the camera is in used) I already tried to reset the settings to default but still the flash wont...
Does the camera indicate that the flash is turned on? In most olympus cameras I have seen there is a lightning blot at the lower left corner of the screen. Verify that it is indeed there and let me know.
Aug 18, 2010 | Olympus FE-170 Digital Camera
Olympus FE-190. The flash won't work. Doesn't fire at all. How do I fix?
http://www.olympusamerica.com/cpg_section/cpg_support_faqs.asp?id=1262
The above is the faq page of the Olympus FE-190.
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
I believe your camera is in need of service after not finding the solution in the FAQs of the camera on Olympus.com.
Try the above link to schedule service.
Aug 17, 2010 | Olympus FE-190 Digital Camera
Olympus FE-190.... video is very dark. cant
go to its settings and fix the lighting for the lcd pannel. then you will be able to see the flash yes or no click yes..
Jan 26, 2010 | Olympus FE-190 Digital Camera
I lost driver cd ,i need drivers & software
There are no drivers needed for the Olympus FE-190. Once connected through its USB, the computer will treat it as a USB mass storage device similar to a removable /flash drive.
If for some reason the PC won't recognize the camera, it is probably a problem with the USB cord, the USB port or the memory of the camera.
Alternately, you can use a memory card reader and slip in the memory card of the camera to gain access to the content/pictures.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Sep 29, 2009 | Olympus FE-190 Digital Camera
Flash doesn't work (ever). got it wet
Water on or in any kind of camera can spell doom to the inner workings and circuits.
If the camera ever gets any kind of water inside, the chances of fixing the camera is not good.
Something which could be tried when any kind of water gets into a camers's insides is this:
Immediately remove the battery or batteries. The reason for this is that the circuits are live when a battery or batteries are installed. This can lead to damage and shortages which will lead to all kinds of circuit troubles.
My suggestion is to sell the camera on a site such as Ebay for parts, as is, or repair parts.
The reason is the the repairs more than likely will cost more than you want to spend.
Aug 31, 2009 | Olympus FE-190 Digital Camera
My camera isnt working
if the picture turns all white, then you might have a problem with the screen.
-or your're just aiming it at a bright object. (try covering the lens with your hand- dont actually touch it, just block out the light and if the screen goes dark then its still working)
if some sand or grit got inside your camera, then you have a serious problem, as sand is very abrasive,and could damage the internal mechnisims.
you should seek professional help on getting the inside cleaned out.
May 03, 2008 | Olympus FE-190 Digital Camera
I need the drivers for my fe-190 digital camera can you help
Nov 12, 2007 | Olympus FE-190 Digital Camera
Broken screen
Sounds like the LCD. Setting anything next to it, bumping it may crack the screen
Oct 20, 2007 | Olympus FE-190 Digital Camera
Olympus FE-190 Digital Camera Logo
82 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
