Question about Frigidaire Refrigerators
How to I reset my frigidaire FFHB2740PPBA? My ice maker stopped working again and I don't want to call a repair man again.
SOURCE: Ice maker stopped working and no Water in Ice maker,,,
I had this same thing happen and I just fixed it! After returning from a long trip, I threw out the old ice (now mostly shrunk), but no new ice was being made. The tray where the ice is made was completely empty/dry (maybe any ice cubes there had "shrunk" away to nothing as well? perhaps part of what keeps the freezer "frost free"?).
So I filled the tray with water using a small measuring cup -- which is what the manufacturer suggests when the refrigerator is new. Now it's making ice again just fine! This might or might not work for you, but trying it won't cost you anything.
Posted on Feb 09, 2008
SOURCE: Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Posted on Jun 19, 2009
  • 7 Answers
SOURCE: LG french door with non working ice maker
Similar problem. Occasionally my ice maker goes on the fritz. Usually I can turn off the ice maker and place a piece of newspaper over the freezer holes for overnight and it starts making ice when I turn it back on. This time that didn't work so I unplugged it this morning for 3 hours and put all the stuff in coolers. I opened all the doors and removed the freezer bin (just the bin maa'm, not the frame) so I was sure the water lines inside the fridge doors and sides would unfreeze. Plus side is the Fridge got a good cleaning. I just heard my first ice drop about a 1/2 hour ago.
Posted on Sep 08, 2009
heatman101
  • 43501 Answers
SOURCE: Frigidaire Side by Side Ice Maker Not Working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
980
Posted on Sep 30, 2010
  • 146 Answers
SOURCE: Frigidaire Gallery Professional Series -
you will need to replace the water inlet valve, this runs your water and ice,, before you replace it take your water line off and hold it in a pot, then have someone turn the water back on , this will let you know for sure you are getting water to the valve,, if no water comes out then you have a water line prob,, have that fixed then hook it back up and turn it on, then you will need to run the water for about 2 -3 minutes to purge the air out of the line,,, if you rplace the valve you will need to purge also
Posted on Jan 19, 2011
heatman101
980
May 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
check to make sure that the fill tube has not become blocked with frozen water.
Feb 23, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice maker stopped working. The water is cool, the filter is new. Dispensing water, but no ice.
It sounds like the solenoid valve has failed. This is what regulates the water to the ice maker. Have it replaced and that should take care of the problem. Hope this helps. Good luck.
Aug 10, 2009 | Whirlpool GoldĀ® GC5NHAXSY
My ice maker crushes all of my ice as it comes out the door. Help me - I'm strictly a cube kind of girl!! Cindy ( I've already tried to push the "crush" button and then the "cube" button again. The...
unplug the fridge 2-3 minutes and see if it resets the computor to make the ice control work normally again. You can also open up and get the cubes out cheaper than having it repaired. Sorry about that!
May 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maker not working properly
Hey, I would check water filter if it has one and the water line to water valve at the back of refrigerator. I'm thinking dirt or something when they work on water problem in other unit.
Sep 08, 2017 | Frigidaire Model: PHSC39EHSS
Ice maker connection keeps cracking and flooding my house
sometimes ice makers get iced up inside the fill mechanism and causes this to happen. Have you tried defrosting the freezer? This may take care of your problem.
Mar 13, 2017 | Frigidaire FRS6R5EMB Side by Side...
I would check the ice maker assembly itself, perhaps an ice cube has not completely exited the mould,and is preventing the ive maker form cycling again
Jan 10, 2009 | Maytag 23 cu. ft. Side-by-Side...
Ice maker cycling but getting stuck
Either you have a bad heating element (soften the ice to eject) or a stripped gear in Ice Maker either way it will have to be replaced by the time you buy the parts and install them you can just replace the ice maker as a unit
May 10, 2008 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire side by side MRS22WNGD0 stopped dispensing ice and water
Even you find the problem you should need special equipment.Better call a technician.This link may help you:
http://www.appliance-parts-warehouse.com/frigidaire-parts/Frigidaire-Refrigerator-Parts/Frigidaire-Parts-MRS22WNGD0.cfm
Nov 18, 2007 | Refrigerators
Ice maker only works for short time
I HAVE THE SAME PROBLEM WITH THE ICE MAKER FRIGIDAIRE FRS22WNC. IF ANYONE HAS AN IDEA HOW TO SOLVE IT PLEASE EMAIL ME TO HYATZFT91@AOL.COM
HIGHLY APPRECIATE IT.
NICK
Sep 07, 2007 | Frigidaire FRS23H7C Side by Side...
Refrigerators Logo
103 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
