Question about Coby MP-C7082 Digital Media Player
Adding photos How do I add photos to my coby MP-C7082. I have downloaded windows media player and draged photos and it always says error
Re: adding photos
You have to manually add them.
Go to my computer, then click on your mp3 players drive name, then go find your pictures, copy them, then paste them on your mp3 player. That should do it.
Windows Media Player does not support synchronizing images or videos.
Posted on Mar 26, 2008
0 characters
3 Points
Do i need a drive attached to my coby mp3 in order to drag and drop pics? i tried but it will not save to my player. i have a vista os on my pc
what error do you get?
Disk is write protected - turn hold switch off on the unit.
Make sure unit is set to MSC mode in your settings of MP3 player, it might be called ONLINE mode, set it to DISK
Feb 10, 2010 | Coby MP-C7082 Digital Media Player
I synced music from windows media player to my coby MP-C781 MP3 player and now it wont power on. And I've tried everything
what I would do is plug it back to the computer and if that works what you should do is go to the manufactures website and download new firmware for your player and reflash the player and try draging a dropping the music instead of using windows media player. this is how you can drag and drop:
first off find where your music is stored and open up that window then open up a window with you mp3 player in it and drag and drop the music into the window with your mp3 player
Sep 29, 2009 | Coby MP-C781 MP3 Player
Wont do anything
In this case pls check whether the Mp3 player is locked there will be switch on the Mp3 player which will say Lock or Unlock just slide it to the Opp side...... I hope it will work fine.....
Jan 16, 2009 | Coby MP-C7082 Digital Media Player
What kind of video file does the coby mp-c7082 play? Also, how do i download these files to it?
The software, esp the AMV converter necessary for converting movies, can be found by entering your model # at:
I had to click on support -> mp3 & Mp4 and then the exact model # - I couldn't get to it through the regular mp3/mp4 page - trust me, it's there
It supports AMV format only, so it must go through the AMV converter on the Coby website
Jun 22, 2008 | Coby MP-C7082 Digital Media Player
Downloading video
Use the video conversion software utility included on the Installation CD to create video files that
are suitable for playback on the MP-C7052.
Your player supports AMV files with the following specifications:
160 x 128 resolution at 15 frames per second (fps)
The video conversion software will not recognize ALL types of video files, so you will have to find a free converter that will convert files of one type to AVI or another recognized video type.
Look at the help files in the video converter software for far more detail than we could ever hope to provide here.
-Tha Mp3 Doctor
May 27, 2008 | Coby MP-C7082 Digital Media Player
have you tried using windows media player? just plug the usb up and select sync, and start down loading
May 09, 2008 | Coby MPC-848 MP3 Player
Cannot synk to download music
If the computer is not recognizing the Coby, then Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 13, 2008 | Coby MP-C7082 Digital Media Player
Request DRM Time
The DRM license on your songs was for a fixed term - right click an individual song that is giving you this symptom, click on Properties, and click on "license" or "digital rights" or however your particular configuration words it, and acquire a new license. you may have to renew your music service subscription to renew the DRM license, and then resync the player one more time.
-Tha Mp3 Doctor
Mar 29, 2008 | Coby MP-C7082 Digital Media Player
Won't show up on my computer
When you open Windows Media Player, does it show an icon of your coby mp3 player? if so, just double-click the Coby icon, and bring up the song folders that way.
Feb 17, 2008 | Coby MP-C7082 Digital Media Player
Coby mp-c7082
I would recommend you to try to format your device and try again...format it inside windows media player...
Jan 01, 2008 | Coby MP-C7085 MP3 Player
Coby MP-C7082 Digital Media Player Logo
57 people viewed this question
Top Coby MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Coby MP3 and Digital Media Player Expert? Answer questions, earn points and help others
