Question about Bosch Washing Machines
The drum is not turning in my vision 800 Bosch washer
3 Suggested Answers
SOURCE:
SOURCE: Bosch Vision 800 Series front loading washer.
We had this same problem last night, although we had just purchased this washer 'new' (bought it at Sears, display model, and it's 9 months old but had not been used). We didn't even get the correct user's manual with it, but after running one cycle without laundry the message went away.
Posted on Sep 02, 2010
SOURCE: Bosch Vision 300/500/dlx Series Clothes
Im getting an error e13 message and don't know what to do
Posted on Sep 06, 2011
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
How do I find the codes on my washer bosch 500
On http://www.onlineonderdelenshop.nl/blog/storingcode-fout-code-bosch-siemens-wasautomaten-wasmachine/ you can find some Bosch codes in Dutch with some explanations.
Oct 19, 2014 | Bosch WFVC540SUC Vision 500 Washer in...
What kind of cleaner should I use for my clothes washer ?
We had black flakes getting into the wash drum thru the drum holes. We ran one gallon of white vinegar through a regular cycle with great success.
Oct 04, 2014 | Bosch Vision 500 Series Front-Load Washing...
Bosch 800 next dryer (WTMC8321US/CN) - makes grinding / rubbing sound when turned on - drum turns very slowly.
This ccan be the result of the skid pads being worn that the drum goes around on. If you can take the front panel off the dryer, the drum will be sitting on plastic skids mounted on the frame. The other thing to look for would be to see if you have any rubbing marks on the inside of the front panel to indicate it needs a little adjusting.
Oct 12, 2013 | Bosch Dryers
Bosch vision error code E01 on washer
error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
Aug 23, 2013 | Bosch WFVC5440UC Washer
Bosch washer door is locked
Remove the cover on the lower right corner, you will see a white plastic pull cord. Pull the cord and pull open the door. Don't force the door, you could damage it. If that doesn't re-set the door lock you will need to replace the lock.
Pl click if helped.
Mar 08, 2013 | Washing Machines
I have a vision 800 series laundry washer. I have a "check Pump" error. From what I have read I need to clean the pump filter. Also from what i have read I need to remove the bottom panel but...
Our (older) Bosch has 2 visible plastic '90 degree turning' screws holding the bottom front panel on. On some others the screws are covered by plastic caps. If yours has neither of these it could be that the cover should simply 'unclipped' by pulling at the ends.
John C
Apr 05, 2011 | Bosch Nexxt 800 WFMC8400UC
Bosch Vision 800 Series front loading washer. Flashing "water level is too high". We are not getting any water into machine at all. Is there a way to reset?
Aug 09, 2010 | Audiovox Bosch 718 World Cellular Phone
Washing Machines Logo
41 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
