Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Display Screen when Charging
When charging the MOTOKRZR is the display screen on the outside of the phone always supose to be lit up until the phone is unplugged from the charger?
  • 51 Answers
Posted on Dec 11, 2007
Motokrzr k1 display shows white blank how do i got
Hi there
The problem with your phone is the flex,
The flex is a cord that connects the screen to the phone panel,it is found in all flip and slide phonesthe flex of your phone has either shifted position or is too weak..
Try opening up your phone,you will see a cord that connects the screen to the panel of the phone. try removing it(be very careful) and fix it back in place.
Assemble the phone and put it on to see if works,if it doesnt work then the flex has to be changed for your screen to come up again.
Please if you can do this yourself you should get a person with experience to do it for you
Jul 08, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Display not comimng up when switched on
The screen cannot display anything, not even the charging display because the flex of the screen of your phone is faulty.
All you need to do is to replace the flex on the screen of your phone in order for the screen to display.
Take care.
Apr 21, 2010 | Sony Ericsson W550i Cellular Phone
Inner screen wont work. i have changed flex cable. its the k1
If the main screen isn't working but the outside (CLI) screen is, then the problem is almost certianly that the actual LCD has failed - although it is worth reseating the flex cable from the LCD screen to the display board just in case.
Oct 08, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
External display stays lit when charging
don't worry everyone's env does that and nobodies screen has burnt out yet and if it does which is highly unlikely verizon or LG will have to fix it.
Aug 12, 2008 | LG enV VX9900 Cellular Phone
My battery wont charge
u just shud flash ur phone that is not esay but you need a Famous Phone flasher LIke The Polar box or give up and give it to a phone FIXER!! shop
Aug 11, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
If the inside screen and the outside screen is blank, the possible problem is the LCD flex cable. But if the outside sceen is on
but the large inside screen is blank. The large screen could be defective.
Aug 11, 2008 | Motorola Mobility V300
Display shows "Not Registered"
1. Remove battery from phone, and unplug from charging cable
2. Unplug Phone base
3. Hold Page button on base and plug it back in. While holding page button wait for in use light to go solid. Once solid unplug base.
4. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
5. Press 0
6. Unplug power from phone pod
7. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
8. Hold the page button on the base and plug it in, Hold page button until the in use light blinks. Let go of page button.
9. Press 9 on your phone. If it says Reg o it is finished. If it says Reg fail try again if it fails twice please call Tech support.
10. Replace Battery
11. Make a test call
Oct 05, 2007 | ClearOne Communications Max Wireless...
Showing not charging display on screen when we hold for charging the mobile.
cause of the fault sometimes is in the charger it might not compatible with your phone try to use another charger, if the fault remain, refer it to service personel, I suggest it is the charging pin problem try to replace it, or maybe in battery terminal should fix the contact to battery.
Jun 22, 2007 | Nokia 6230i Cellular Phone
Motorols Razr Display
maybe when u charge it try having the phone on. see if that works
Oct 16, 2006 | Motorola Mobility RAZR V3
Motorola razor v3 display problem
If the charger is not an original motorola charger,, then you have a problem. make sure its original.
Oct 11, 2006 | Motorola Mobility RAZR V3
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
53 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
