Question about Ericsson Sony Wireless Headset for Bluetooth Phones - HBH60 Headset
HBH60 cant detect my w810i.
Tried a number of times...and cant detect...but now the green light disappear..and it become orange when i press..may i know why?
Re: HBH60 cant detect my w810i. - Ericsson Sony Wireless Headset for Bluetooth Phones - HBH60 Headset Headsets
Posted on Jan 27, 2008
0 characters
3 Points
H700 Motorola Bluetooth Headset
Make sure that any devices previously paired
with the headset are turned off. If the indicator
light is flashing in blue, turn off the other device,
then close and reopen the headset boom. The
indicator light becomes steadily lit in purple
indicating the headset is now in pairing mode.
Jan 03, 2010 | Motorola Mobility H700 Wireless Headset
Cant pair it with my cellphone
Turn your phone's bluetooth on. Press and hold the call button on the headset until the phone detects it. When prompted for a password enter 0000.
Sep 21, 2009 | Plantronics Hama Voyager 520 Bluetooth...
Plantronics CS55 requires lifting handset on phone
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
May 28, 2009 | Plantronics CS55 Wireless Headset
I Cant seems to pail motorola h700 headset to samsung g600
Well, it sounds to me like you know how to get the headset in pairing mode, have you tried turning off your old e900 and then pairing?
This guide was taken from here.
In standby mode, press Menu. Highlight Applications and click Select.
Highlight Bluetooth and click Select, or just press 4.
Highlight My devices and click Select, or just press 2.
Put your remote device into pairing mode. You can find out how to do this from the manual that came with the device. When the device is in pairing mode, highlight Search new device and click Select.
If Bluetooth is not activated on your G600, you'll be prompted to switch it on. Click Yes.
The G600 will search for all the Bluetooth devices in the proximity. The type of device will be indicated by the icon to the left of it, so you can clearly see if the device is a PC, a phone or a remote headset.
You'll be asked to enter the PIN number to connect to the device. This is in the documentation that came with the remote device but if in doubt, try 1234 or 0000, as these are the most common PINs.
Once connected, the device's icon will turn orange on the My devices screen, and when you press the red End call key to return to standby mode, you'll see the headphone icon on the top row of the screen.
Your headset will now be paired permanently with your G600. Switch the device off to disconnect it, and next time you switch it on the phone will connect automatically, providing your Blueooth is activated (go to Menu, Applications, Bluetooth, Activation, On to activate Bluetooth).
My apologies for the copy past guide, I have never used a samsung phone.
Dec 25, 2008 | Motorola Mobility H700 Wireless Headset
Pin number for philips SHB6100 aside from 0000.
yeah hedenram is right. my problem was that i was trying to pair something WITHOUT the headset in pairing mode. just switching it on doesnt put the headset in pairing mode and it will reject the 0000 passkey even if this is correct. it is vital when you turn on you hold the power button til it flashes red/green and then it will be in pairing mode and accept the 0000. the only way i found this was in the instruction booklet which i thought i had chucked away
Oct 22, 2008 | Philips VOX120 Wireless Headset
Sony ericson k800i
my cell suddenly goes to my underware n its vibrating.........
so much comfortable is not it
Dec 05, 2007 | Ericsson Sony Wireless Headset for...
Motorola H700 Volume 'Up' Orientation
There is a way to change the orientation of the earpiece and volume buttons. Guest's comment was uncalled for. Suppose you are deaf in the ear that it comes set up for?
Nov 01, 2007 | Motorola Mobility H700 Wireless Headset
Make sure when pressing the volume button that you press the + and the mute together Just reset mine. when connected password is 0000. best of luck
Oct 21, 2007 | Siemens HHB-610 Wireless Headset
1) Make sure headset is off. 2) Press and hold the answer button until the light flashes green and red. 3) If it only flashes green, press and hold both volume buttons until the light lashes red and green. 4) It is now ready to pair: follow the instructions in the bluetooth menu of your phone. When asked for the passcode enter 0000. 5) All done.
Feb 24, 2007 | Sony Ericsson Universal Bluetooth...
Headsets Logo
Top Ericsson Headsets Experts
Brian Sullivan
Brian Sullivan
Are you an Ericsson Headset Expert? Answer questions, earn points and help others
