This happens randomly. Stat is Amana wireless set at 68 and left alone. Compressor makes good heat. Sounds good. Both coils CLEAN. 1st stage Works perfectly several cycles then for no reason 2nd stage only then back again no apparent pattern
SOURCE: Kenmore
when its running how hot are the sides the starting amps are too high and 1.5 running amps ain't bad now the the cut in cut out are too high if you look on the dial that the mid point settings that's where you should have it not on 1 1 is hot set it on the straight line that's where you should do all your testing colder settings go up not down you could be overheating the compressor by making it come on too quick the freezer should be about -10 or so do you see any gaps in the gasket
SOURCE: Grip pen not responding
You could try recalibrating the tablet. Open the tablet control panel, then click "About." Then hold Control while clicking "Diagnose..." and on the next screen -- the Diagnostics window -- you'll see a new button labled "Recalibrate..." Clicking that might do the trick.
Good luck.
SOURCE: Heat pump blows heat half the time and cold half the time
It sounds like it is just going into the defrost cycle. Go outside and see if it is iced up. If it is, it reverses itself to melt the ice. Heat strips should come on if unit has them
SOURCE: Heat Pump Cycles On and Off and Air Handler Noisy
I am pretty sure you have a low charge and the pressure switch is kicking it off. probably just a pound or two however the accumulater will sometimes hold more.
