Question about Hobart Food Mixers
Tutorial on how to replce liftbowl belt on a m802 mixer
Why bowel not lifting after i put together
This is a kitchen device (mixer). I suggest you stop trying to use it as a medical device.
Jun 01, 2014 | Hobart M802 80 qt. 3 HP Dough Mixer
What oil should I use for the Hobart Mixer P660?
A good standard 90 wt oil is what is ok for the gearcase. This is an old email from a hobart service tech and they recomend a special oil ordered from them. So you can decide which you want to use. "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer -
Sep 23, 2011 | Hobart P660 Stand Mixer
What type of gear lube should I use for my Hobart H600 mixer?
Hi, btperduell
below is a copy of an e-mail from Horartservice.com. I searched the web forhours for the correct oil and could not find any info so I e-mailed Hobart. The Planetary is a different part from the transmission andthe sight glass on a M802 is for the oil in the transmission. The answer that Hobart gave is not an NSF oil. Ineeded the oil for the planetary section on a model M802. Even the directionssay that it is normal for a drop of oil to occasionally drip from the seal.That is where the dough hook attaches. I am in the process of researching the oil and Exxon / Mobildoes make a NSF version. I just need to find somewhere I can buy less then a 55-gallondrum. The above mixer only uses 6 ounces. Take care and stay safe Thank you Mike Hobart E-mail follows ============================================================== Mike, Hobartuses "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer - Food Machines Product Service - Tech Support
b>
Jan 15, 2011 | Hobart HL600 Legacy Stand Mixer
Blender attachment does not work
It could be the drive belts. There are three. One for the motor to the belt drive. one from belt drive to bowl mixer spindle. one from belt drive to mixer spindle. mine started to do the same thing. I ordered the belts from Bosch.
Jun 08, 2010 | Bosch 700 Watts MEK7000 Concept Series...
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
Hobart m-802 mixer won't start up
call Hobart for the correct oil any way and an elcetrican will just add more problems for yoy
May 30, 2009 | Hobart A200 Stand Mixer
90quartmixer gears dont have power belt torn
Is the model an M802?Did the belt break or slipping?I'm a hobart tech,let me know.
Mar 03, 2009 | Hobart H600 Stand Mixer
Looking for location of drain plug for m802
Look behind where the dough hook is near the pedestal,its a three quarter inch bolt.
Feb 21, 2009 | Hobart Food Mixers
KitchenAid KSM90 motor runs, but beaters don't turn
I feel your pain. I own a new Kitchenaid, and for some reason they changed some of the metal gears from metal to plastic on the newer models. I suspect it was to make it quieter. But they strip out. Happily, the replacement gears they sell are metal, and once replaced will last a lifetime.
You will either need to replce them yourself, of find a repair shop.
Aug 07, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
73 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Steve Allison
Steve Allison
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
