Question about Belkin N1 Vision Router
Belkin N1 Vision
I am trying to set up my belkin N1 vision so that it shows the name of my playstation 3 xbox 360 and psp in the display window
At the moment it shows Unknown device plus a number for each of them
  • 2 more comments
  • Anonymous Jan 17, 2008
    same here , the only device that shows as a name is my pc, my 360 and nokia n95 just show as unknown
  • Helio_Pilot Jan 21, 2008
    ON mine the only names are the Wireless Laptops, my PC even shows as unknown.
  • slainangel Jul 13, 2008
    Devices show up with a correct name when they're first connected, but switch to "unknown.101" and similar pretty quickly.
    Wireless devices lose their name as soon as they go out of range, but get a name again once the DHCP lease expires and a new one is issued. Wired machines have their names until the router crashes (usually a couple of days).
    Could solve this by setting a shorter lease period - so the computer has to request a new one, reminding the router of its name. However, there's a problem.
    Most of the computers here talk to each other on the network. If one gets a different IP, the others can't connect (given that the router's DNS server apparently doesn't resolve local names correctly, and there's no way to set a MAC-IP mapping so that the same machine gets the same address)
  • MrGadget2000 Jan 28, 2009
    I don't quite get the DHCP Host name thing - I would like my PC's (XP & Vista) and my PS3 to reflect something othernath 'unknown.2' etc but I've look through the PC network settings and those on the PS3 and can't see anything relevent. All of these devices are wired if that makes a difference.
    Any pointers?
DHCP Host name is what your looking for.
you need to name each item ie. psp as psp and ps3 as ps3 when you setup each item for connection. so when you setup or edit the settings for your ps3 on your ps3 you need to look for DHCP Host name and name it ps3. etc
do the same for all.
Posted on May 25, 2008
Belkin n1 vision is shutting down
Is the Belkin plugged into a power strip or UPS? Try another AC outlet. Has the AC jack,plug in the rear or the Belkin been damaged due to pulling on the AC cord, causing a lose connection? Is your computer shut down at night? No Hibernate, No Sleep? Are their setting for the Belkin to shut down/timeout after a certain idle time? Here's a user manual:
Feb 14, 2013 | Belkin N1 Vision Router
Belkin n1 vision router freeze up. download mode or looping in bootup mode. what next?
Disconct wireless devices...connect to pc via cable...Go to SSID settings... change bandwidth from 20/40mhz to 20mhz only ... rebooting issue will be soloved... link speed will show 65-150 Mbps .. bt dont worry.. u will get the whole bandwidth available .... after that reconnect wireless devices ... it wont reboot by itself ...
Jun 19, 2011 | Belkin N1 Vision Wireless Router
Can the belkin n1 visoin, support nat type 2, connected to a playstation 3?
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Nov 05, 2010 | Belkin N1 Vision Wireless Router
Hi i am using Belkin N1 vision version 102uk when ive plugged this in to the sky adsl router, it is showing no router detected?? can you help?? regards chris
1. check connection by 1st pinging the network card That is go to the dos window and type " ping you should get 4 replies.
if not then you need to check the driver set for you network card.
2. check the ether net cord with a know good one
3. reset the router by unplugging it and reboot the pc
4.Call your ISP to check for outages
Aug 03, 2010 | Belkin N1 Vision Wireless Router
The router wont set up a wireless connection in the xbox so the internet does not work.
you need a wirless device to plug into the xbox 360 or u can use a long ethernet cable
Jun 27, 2010 | Belkin N1 Vision Router
For some reason the router says unknown_4 for my xbox 360 how do i fix that
Where did you see that message? Try to set static IP address on your XBOX. Go to Network Settings > IP Settings of your xbox and set it to Manual IP and type the numbers below
IP Address:
Subnet Mask:
Default Gateway:
DNS: Automatic
Reboot your router and xbox after that.
Jul 28, 2009 | Belkin N1 Vision Router
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Xbox 360 router wont work with Belkin N1 Vision.
make sure u are looking for the right connection when the box opens for the connections on the left hand side u will c a small box click it u will get wireless /dialup/vpn just make sure you look for the right one also go onto ur computer into windows media into library options into sharing and search have your xbox on it will appear click on it to allow it to share with your pc i would appreciate it if you could rate this solution
Jan 02, 2009 | Belkin N1 Vision Router
Nat type
Try this link this shows how to forward ports on your belkin router.
Apr 13, 2008 | Belkin N1 Vision Wireless-N Wireless...
Belkin N1 Vision Router Logo
1,200 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
