Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint wd420 leaking
Had the engineer out a few weeks ago for this problem and he removed one of the blue bars from inside the drum and removed what was blocking it ( a doggy poo bag!!!!) got a feeling this might have happened again, anyone know how i remove these bars myself so i can avoid another £90 call out!!! there doesnt seem to be any obvious way but he must have done it some how
Any suggestions please
Many thanks in anticipation
  • jaynew Nov 29, 2007
    Yes the drum rotates fine, thankyou i will get my husband to have a go and post the result
Fantastic. I also had had the washer a couple of years ago when it started leaking everywhere. I removed the blue paddles by sliding and lifting. This let me see the drainage pipe at the middle in the back. With the help of a torch - lo and behold - there was one of my partners g-strings blocking the outlet (!).
Many thanks
Posted on Jul 08, 2008
  • 249 Answers
They are called paddles ,they just slide and lift.can you rotate the drum with your hand??
Posted on Nov 28, 2007
  • eamonn close Nov 29, 2007
    'careful it may not be the same problem'
Leaking hotpoint wd420 washer dryer
Depends on which clip is fitted, if it's the metal type with loops on the ends then you squeeze the 2 together with pliers or mole grips but if it's the plastic type they are like teeth inside and you have to push the middle section outfrom the outer in opposite directions. Can be done with a flat blade screwdriver but be careful of you fingers.
Dec 22, 2012 | Washing Machines
Really silly question, for the above model is there a filter, if so how do you change/clean it?
Yes, there is a filter.
Remove back panel, remove large black hose fastened to bottom of drum, and remove and clean filter inside the hose.
Oct 12, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Leaking water if rinse and spin
Check your pump is ok and filter not any blockage as this is common cause/ Fiter located within sump hose...bottom of drum take clip off to remove.
Apr 13, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint aquarius wd420 cannot stretch drive belt on there is no slide bar on motor which is fixed solid even after bolts are lossened its a washer drier no obvious way of attaching belt
There is no adjustment provided for tensioning belt as it is a stretch belt.
Best way to do it is to remove the rear panel, tilt the weaher forwards, get someone to hold it for you.
Put belt round motor pulley first, then slowiy feed it round the drum pulley, turning the drum pulley at the same time, it will be very tight, so watch your fingers, just keep going until belt is on, if it comes off, just start over
You can line it up properly in the motor pulley grooves once you have got the belt on.
Please rate my solution.
Feb 25, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Machine very noisy when it spins. Missing bra
If you cannot here it catching, then leave well alone, if it is still catching, then you could to try to locate it by removing the lower rear cover of washer, remove the large black hose on bottom of drum, and see if you can locate it from the bottom of the drum.
Hope this helps.
Jan 16, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Not pumping water out
You nead to check the filter.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps.
Dec 14, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Sep 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint wd420
if the drum is tight to turn ,then the main bearings have probably seized, or their could be something fast in the drum. Remove belt, and try to turn the drum by hand , it shuold be free with no resitance.
If it is noisy or feels rough, then the bearings have gone.
Sep 01, 2008 | Hotpoint Aquarius WD63 Front Load...
It´s a wd420. We
Did who ever install this machine make sure that it was installed correctly and draining properly. The burning smell will go away with time.
Apr 13, 2008 | Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
288 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
