Question about HP Pavilion zt1170 Notebook
HP Pavillion ZT1170 CD Activity Light on Solid
I have a HP Pavilion ZT1170 laptop and it does not recognize the CD/DVD. The CD activity light is on solid and does not go off. I tried rebooting (several times) and even took the battery off but nothing helps. I remove the drive itself and that has no effect either. Do you have any suggestions?
Try with a CD/DVD lens cleaner CD. This will rectify any static charge or dust in the lens.
If any heavy phisical impact happend, may be the drive contacts are improper. Conform there is a DVD-RAM Icon presents in the My Computer window. If not found try the following steps.
1. Load CMOS default valus and give a proper start up and check the DVD-RAM drive in your system.
2. Shutdown the system
3. Gently push the drive inside the laptop's base cabinet. Remember apply a gentle force.
4. Turn on the system and check it out.
5. If the above steps failed, Shutdown the system, and remove the drive from the motherboard. Clean the electronic contacts using a pancil eraser or with a nice cloath. Insert the drive again, then verify.
Note: In all the above steps, try with more than 2 CD/DVDs 'cause laptop drives are too sensitive and can not read some CD/DVDs even thay have a little scratch.
Posted on Nov 26, 2007
HP Pavilion zt1170 won't start enecbpth.sys
Please re install the OS on your laptop.
Regards
Feb 27, 2011 | HP Pavilion zt1170 Notebook
Laptop dvd doesn't read disks
follow these steps:
start-my computer-right click-manage-device manager-cd/dvd drives -click update driver then restart your pc and try it .
Feb 01, 2010 | HP Pavilion dv6000z Notebook
My HP Pavilion dv7-1130us won't recognize dvd drive
it sounds like the drivers have gone missing for the dvd drive
you can try system restore or if you have Win Xp Cd
you can try a First Repair to fix the problem
Jan 31, 2010 | HP Pavilion dv7-1130us laptop
Can't use cd/dvd player - computer doesn't recognize it
try to boot the computer using cd. like you trying to install windows. if it read the cd to get into the windows setup, then cd drive is good.
1st make sure you set the option boot from cd first in the bios.
2nd place a windows setup into the drive.
3rd save and exit the bios.
4th if it ask you to press any key to enter setup then the cd drive is good.
maybe u have a windows problem, try to reinstall windows, that the easy way.
Aug 28, 2009 | HP Pavilion dv2000t Notebook
Hp pavilion zv6000 wont recognize dvd+r
Hi Terry,
The answer is pretty simple, the ZV series is about 4 years old, back then DVD manufacturers decided which formats they would support as it was too expensive to make desktop drives, let alone, laptop drives that supported all formats. That drive only works with DVD-R and I believe DVD-RW. If you want to burn other formats, the laptop will only support them if you add an external drive of a newer make.
Note: Virtually all current models support ALL DVD formats and many support BluRay as well.
Hope this helps,
Chris
Jul 07, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Ok I Have a HP ZT1170 Blank HD and dead DVD-Rom
Buy a new a CD R/W, you will need one at some stage and they are not very expensive.
Apr 01, 2009 | HP Pavilion zt1170 Notebook
Laptop hp dv6000 will not recognize cd burner/dvd player
HP Pavilion dv6000 laptop PC
Did you 'turn off' the AUTOPLAY feature of the CD\DVD ? When the player "runs two times at startup", it is trying to find the program on the disc.2nd- Look in internet for HP dv6000 cd\dvd drive replacement.(If that is the ""exact match for the product"" you wrote about)
3rd.goto CONTROL PANEL>SYSTEM>HARDWARE>DEVICE MANAGER and look up cd\dvd and uninstall it. REBOOT, when your system comes back it will try to find the cd\dvd. If it does not, it is damaged (kaput!), must be replaced. If Windows finds the cd\dvd drive and reinstalls the drivers, but it does not work, then the heads are dirty or damaged.That Windows found the dvd\cd means that the circuit on the device works.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
I have an HP 5000 Series laptop. Just installed a new cd/dvd writer...windows still didn't recognize new drive.
Firstly, try reconnectnig it and make sure you push it all the way in. Then try this:
1. Got to Run on the startmenu. And type regedit.
2. Open HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass.
3. Go to the first folder that starts with {4D36...
4. Delete UpperFilter and LowerFilter.
5. Reboot the unit.
If it still doesnt work after this try a full system recovery. If that doesnt fix the issue you might need a new CD-PCA board or mainboard. But it can also be a DOA(dead on arival) DVD-ROM.
For a list of parts and partnumbers go here
Mar 11, 2009 | HP Pavilion N5350 Notebook
Drivers for zt1170
hi sailor08 you can dowload the drivers for your system and save them to disk from here hp site, here is the link
go here http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=73244&lc=en&cc=us&dlc=en&submit.y=6&submit.x=2&lang=en&cc=us
choose your operating system and the next page will have the drivers.
this should supply you with all the drivers you need to get it up and running make sure you save them to a disk.
hope that helps
Oct 20, 2008 | HP Pavilion zt1170 Notebook
HP dv4000 laptop CD not reading
Hi
Type of media settings might be the issue but making a change for standard CD/DVD recording (it affects reading too) Issue can be resolved. Right click on the CD/DVD drive (Usually D drive ) click on properties and select and choose the recording option. Click the enable CD recording for this drive option
Click on apply and OK. Try again. You may try after reboot the computer. If issue persist please post so we can think about some alternate solutions.
Good Luck
Jan 23, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion zt1170 Notebook Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
