Question about RaidMax Scorpio Mid-Tower (Blue) (16116)
Power LED the blue power led will not light up and it is connected right, hdd leds working fine
    President:
  • 2,351 Answers
Remove the hdd connector from the Mb. Borrow or buy a hand help AC. DC OHMS meater.
Run a OHMS test across the two pins. If OHMS reads zero the bulb is bad.
Posted on Dec 23, 2007
The led on the front won't light, and I have power connected, but nothing. Is there a reset somewere?
I am assuming you are trying to power up an installed motherboard, based on the category selection. You say that you have power connected. That means that you have connected the 20 (24) pin main connector and the 4 or 8 pin CPU power connector to the motherboard. Have you connected the front panels controls to the motherboard header? There are connections for the power switch, power LED, HDD LED, reset switch (optional). They must be connected in order for the motherboard to start. THe HDD and Power LED connections are polarity-based, so if you hook them upo backwards, their respective LED will not light. The HDD LED plug is usually red and white with the red being on the positive (+) terminal. The Power LED plug is usually green and white with the green wire going to the positive terminal. The power switch and reset switch wires can be connected either way as they are not polarized.
Jul 14, 2015 | Computers & Internet
What colors are the wires for the pwr sw, smi,rst,hdd led,grn led and where so i plug them in at s7sen 15-a01-013010 rev 3.0a
- the colors of the wires (can differ, depends on the case type):
  • Green(+ is the colored wire)-White(-) --> POWER LED (GREEN light)
  • Red-Black -> POWER SWITCH
  • Red-White -> HDD LED (RED light)
  • Blue-White -> RESET
  • Red-Black (4 pins wide)-> SPEAKER
Sep 03, 2010 | EliteGroup K7SEM Motherboard
How to connect HDD LED & POWER LED & RESET LED & 2 others who is blue and whid & my SPEAKERS, can you help me here?
don't you have the book for the motherbd? Most motherboards tell you right on them wat connection goes where. look for them they should be in close vicinity of each other Usually.... HDD-Harddrive connection./.RST - Reset /pwr-- to switch ....etc....
Oct 16, 2009 | Asrock ConRoe945G-DVI Motherboard
I cant get the HDD LED to work... yes it is hooked up right...
Some of the wires going from the power switch, reset switch, speaker, and LEDs must be attached to the motherboard the correct way. That is, they must not only be placed in the right spot where they need to go, but they also must be connected with positive and negative wires on the right pins.
If your HDD LED is not lighting up when the HDD is "thinking", try reversing the cable where the HDD LED wire plugs in (just flip it so the black wire is where the non-black wire was). I tried to find a good picture of your motherboard to guide you but they were not very helpful. From squinting really hard, I believe the spot they should plug into the board is by the CMOS battery. There might be printed words on the board surrounding the area to connect them that tells you which two pins are for the HDD LED.
Mar 03, 2009 | Gateway (4000782) Motherboard
I have a intel 478 board an don`t know how to connect power poer led
The power led wires ( there are two) go onto the two pins on the top row of the front panel coonetcor block on the board, on the 1st and 2nd pins working from left to right.
The full connector block is wired as follows:
top row: left to right >>
1st& 2nd are Power LED, the 3rd & 4th are the power switch, the 5th is empty.
The bottom row: left to right >>
1st & 2nd are hdd light, the 3rd & 4th are the reset switch, the 5th pin has no connector to the pin
Note: the power led and hdd terminals are to produce a light when the pc is on and busy.If the lights do not show, turn off the pc, turn the connectors round 180deg, reconnect and turn back on again. Job done
compdoctor2005@btinternet.com
Dec 10, 2008 | Computers & Internet
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
The same like everyone but know answers like everyone pw, hhd, power led
have a look on the techguys tab at pcworld.co.uk, you will be able to download the maual from there
Nov 13, 2008 | E-Machines eMachines T3830 PC Desktop
JFP1 connection
Hi Yannick,
For the POWER and RESET connectors, it does not matter which way you connect the pairs. Both ways will work. The HDD LED coupler will only work if connected the right way. You can however try it both ways until the LED works. You cannot damage your board if this is connected the wrong way.
Hope this solves your problem.
Oct 16, 2008 | Computers & Internet
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Connetors front panel
you will see underneath the panel pins, where they are supposed to go, there will be +HD Led-, in this case it is positive to the left and negative to the right, work out which wire is your positive, usually red.
When you power up check that the Power Light is on and HDD light is flashing, if they arent take the connector out and turn it around.
If this doesnt work please post you Mobo Serial number here
Dec 18, 2007 | Intel D850MV Motherboard
Open Questions:
See all RaidMax Scorpio Mid-Tower (Blue) (16116) Questions
RaidMax Scorpio Mid-Tower (Blue) (16116) Logo
207 people viewed this question
Top RaidMax Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
gaucherre
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
