Question about Samsung SP42P2S Television
SP42W5HFX menu problem
Hi i have a Samsung SP42W5HFX and although the picture and sound are fine every time i bring up the menu and then exit it leaves a bitty imprint on the left hand side. If i use the volume button it leaves small lines where is was. Any help would be gratefull Jason hi i have the same problem with this tv (samsung sp42w5hfx, have you got any solution??
    Scholar:
  • 137 Answers
Here is what going on. This is a internal fix. You need to do a small voltage adjustment. There are 2 controls. Your VS adjust and your VA adjust. Maybe your VE adjust. Look inside the panel there will be a sticker with the correct voltage. Just adjust accordingly. Be very careful. These are very important adjustment.
Best regards
Circuitcity
Posted on Dec 06, 2007
My Samsung galaxy ace,GT-s5830i does not ring when I get a tex although it use to.sudenly stoped or I pressed something I should not have.
Most Samsung Android phones have a setting button, press it and find "Sounds and Notifications" in the menu and press it. Find " Other Sounds" on that menu and press it. Cursor down to the bottom of the list and find "Messages" and press it. This should bring up a menu Containing notifications selection, sound for the notification selection. Find the sound you want and press it and then press OK. Close the settings area and your messages should now announce themselves with the sound that your selected.
Jan 16, 2018 | Samsung Cell Phones
I lost my sound on my Samsung LN-T4061F tv. it was plugged into my stero.. was fine.. and now no sound. Not even on the regular tv. HOw do I get the sound to work at least on the regular tv?
hi,
i think ur tv's internal mute function is ON. change it to OFF through the following setup.
1. Press the MENU button to display the menu.
Press the ? or ? buttons to select "Sound", then press the ENTER button.
2. Press the ? or ? buttons to select "Internal Mute", then press the ENTER button.
3. Press the ? or ? buttons to select "OFF", then press the ENTER button.
Press the EXIT button to exit.
ok
Dec 14, 2010 | Samsung Televison & Video
Samsung t240hd, turn on, no picture, just sound. only had it less than a year! HELP!
did you find a solution? mine is the same. get a picture for about a second then it goes blank. it's not an input problem as it does the same whatever the source and you cannot bring up the menu on screen. audio works fine but no image after first second.
Apr 26, 2010 | Samsung T240HD 24 in. LCD TV
How can i erase the current pictures on my frames memory card to replace with other pictures?
Remove any SD card, turn on the frame, then press the "Exit" button 1 time on your remote. You will see the side menu flash, this indicates that you can now navigate up or down in that menu(Press enter on remote to activate the highlighted sub-menu) Press "Exit" again this puts you in the Media Memory menu, navigate to "Internal Memory" Press "Exit" one more time, this will allow you to navigate through photo's stored in the internal memory. Now if you press "Setup" on your remote it will bring up the copy/delete menu! navigate this menu with the up/down arrows on your remote to which ever option you prefer, press "Enter" to execute the highlighted command.
Don't forget to let me know if this helps anyone!
Dec 26, 2009 | SmartParts INC. digital frame. 7.0 in....
Gray box on screen with sound.
It sounds like you need to turn off the text mode in the closed captioning menu,
Jul 23, 2009 | Samsung HLT6187SAX 61" DLP HDTV
Samsung rear projection tv wont turn on.
Replace your STK ics both of them. STK392-040 go by number on parts
Nov 15, 2008 | RCA D52W19 52" Rear Projection Television
Samsung u900 Soul mobile, both ring and caller volume is to quiet even when set at maximum. Is there anyway of increasing phone settings
I am having a screen color problem, the color split and does not seem to be correct, please help regarding this
May 08, 2008 | Cell Phones
SAMSUNG REAR PROJECTION TV SP42W5HFX - WON'T TURN ON
common problem with these sets is the convergance ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
however with out troubleshooting it it's hard to tell you might want to contact pts see how much to fix the board.
http://www.ptscorp.com/
Dec 14, 2007 | Televison & Video
Convergence problem with samsung sp42w5hfx
Hi.
Post your email address & I will send convergence set up manual.
http://dysonmanuals.inc.io/
Chris..
Nov 04, 2007 | Televison & Video
Samsung rear projection sp42w5hfx convergence problem
Compare IC connections with meter = check solder joints to
see if some are touching one another. Tell me exactly what
brand & part number was installed...........T.
PS. The red,green,blue plugs may be mixed up because the green should stay and red & blue move !
Nov 03, 2007 | JVC AV-48WP74 48" Rear Projection...
Samsung SP42P2S Television Logo
96 people viewed this question
Jerry Greenberg
Jerry Greenberg
