I have an error code, SC 547 on a Ricoh Aficio 1075. I know that is noise on the ac power, but i've changed to other power source and i still have the problem. Is any other reason or procedure to clean this error?
Have you tried sc reset through the service mode and then turn off .. you can get to this by pressing yellow clear button then 107 then hold down the cancel stop button..wait for the screen to change then go to mode 5 and you need to arrow down to sp 5 810 sc reset execute turn off the copier and try turning on to see if it clears.. if not the ac board maybe defective caused by a power surge or static down the line..
Ricoh Aficoio 1075 Erro Coad SC 322
I changed the thermoster and i got it workin
Hi
Error code sc 547 means "Zero cross signal malfunction". This error appears due to a faulty power supply. This error code may also appear if the input board is defective or the BIC Unit is defective. Turn off the printer and unplug the printer for 30-40 minutes and check if the error still appears. If you see he error still appearing then try and rest it using the following reset method--
To reset the SC code by entering SP5810 and select 1.
Now hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, you'll need to check and replace the Power supply or the Input (IOCC) boardt.
Hope it helps...
ricoh np1500
