Question about Kitchen Ranges
F9 Display in Model MGR5770ADB Gas cooking range
I have a Maytag Model MGR5770ADB Gas cooking range purchased in Sept 2000. After a manual clean up, we find that the owen light is still on after closing the door and a fault display F9 comes on in the display. Apparently, the light switch doesn't get depressed when the door is closed and I'm not too sure, whether the F9 display has anything to do with this problem..
Any help in this regard will be greatly appreciated..
  • Anonymous Mar 05, 2009
    We had a loss of power in our neighborhood today. When the power came back on, our Maytag gas range was beeping and f9 appeared on the display, the oven door is locked. When we hit the "cancel" button, the f9 will be replace by the clock, and the range will have a clicking, rumbling noise for a few moments, then f9 comes back on, and the range beeps just once. The oven door lock never releases. We've tried flipping the circuit breaker, but that's not making a difference. Is there anything else we can try?
    Locked Out
  • 213 Answers
F-9 means you either have a bad door latch hinse the light staying on, or the ERC which is the oven control has a stuck relay and youd have to replace the ERC to fix it.
Posted on Nov 27, 2007
Hi Chris, Our oven would not broil or bake. We are not sure on how to make it broil or bake. All it displays when is F1 after we did all the setting. Any suggestions, or instructions please post. Thanks for your time. MrZhuKeeper
Posted on Dec 28, 2007
I have a Maytag range that is displaying F9. The oven door is locked as well as the cook top that allows finding the model number. Please help if you can. I appreciate it so much.
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Aug 07, 2011 | Maytag Ovens
My sister has a Maytag Advanced cooking system - MGR 5880 BDS - they used the self clean last night and now today the door will not come unlocked and a error F9 is showing on the display. How can they fix...
The F9 code indicates that you have a problem with the door lock circuit in this type of range. It is possible that you have a wiring failure in the door lock circuit. I recommend that you unplug the range and check the wiring connections on the door lock switches. I provided a wiring diagram in the image below. If you find no wiring problems, then you could normally try to fix this problem by replacing the door lock assembly.
Mar 20, 2011 | Maytag Kitchen Ranges
Maytag advanced cooking system manual MER5775Q, how to resolve a F9 error message and also get rid of the "lock" notice
Hi stuartwri190,
Kindly check the door latch components. The F9 fault code is about the door latch.
Hope it helps.
Thank you for using FixYa.
Aug 15, 2010 | Maytag MER5775Q Electric Kitchen Range
My Maytag Gemini range has a F9-4 code when trying to clean?
Hi There
I have found this code for you and hope this is helpful.Let me know how it goes.
F9 Door latch Check door latch components.Best Regards Richard
Jan 06, 2010 | Maytag Gemini 30" Self-Cleaning...
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Clock display/oven control panel
a few screws will drop rear panel to check connections, , check your power supply as wellpossible bad connection at outlet
Feb 25, 2008 | Maytag MGR5770 Gas Kitchen Range
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Kitchen Ranges Logo
451 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
