Question about RCA Televison & Video
I have RCA Model RLDED5078A-D TV and have no sound.
Check audio see if speakers on if ok check input or source
SOURCE:
  • 86 Answers
SOURCE: Blink on Sharp Aquos LC-32D43U
If your using a HD converter box, there is usually a blink when switching from an HD channel to a non HD channel. It is just adjusting from different pictures modes such as changing from a 480i channel/show to a 1080i channel. If this is the case, its perfectly normal.
Posted on Jan 20, 2008
MrBob84
  • 90 Answers
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Posted on Feb 13, 2008
  • 905 Answers
SOURCE: component input- no audio/video signal
copy protect circut may be going bad or the component cicut has now failed
Posted on Oct 07, 2008
anasmaq
  • 100 Answers
SOURCE: wireless speakers to audio devices having no audio output
you can find all kinds of adapters for RCA or phone jack to anytype of connectors at best buy or circuit city, if not Radioshak probably have them. just ask for a cable adapter to the type of connector transformation you need for the speakers.
Posted on Dec 30, 2008
  • 31 Answers
SOURCE: I have been trying to
The RCA audio plugs on the back of your TV are for input only, the only way to get sound out of the TV is to use the Optical Digital Audio Out plug in the back of your TV.
Posted on Feb 28, 2011
I have it setup on my Samsung TV with RCA cables, but no sound comes out
Why do you need to use RCA cables as a TV will produce sound through the internal speakers without any cables required.
May 24, 2016 | Samsung Televison & Video
Manual says only audio inputs are output to the rca audio outputs. How can I get digital audio inputs to output to where I can connect wireless speakers.
Does your receiver have a set of rca connectors labeled "tape out" or "tape monitor" those might work as a better output. As far as the delay goes, if you have your tv hooked up via hdmi, then you will not be able to get the audio to sync up with it. the tv takes longer to decode and display an hdmi output than your receiver does for an audio input.
Jan 14, 2016 | Marantz SR6001
Trying to hook up surround sound receiver just like the manual shows but I cant get any sound from the tv but I can get music from the tuner part any suggestions?
Have you enabled the external speaker option on your TV and the set isn't on Mute? Check that you have the surround system's receiver set to the correct input. Next, check the audio level. On some sources for the TV, I need the volume at 65. Other sources sound fine with the receiver at 45. Check that the audio matches that being sent by the TV. On my TV, I needed to go to the Menu > Audio Settings to find the option for turning on the external speakers. Then I had to set the speaker system to Multi-Channel for our specific setup. (There were several options, including Dolby. For my specific setup, these other options didn't give the correct sound.) Finally try a different audio cable between the TV and the receiver.
I hope this helps. Please add a comment with the make and model number of your TV for additional advice. Adding the type of connection (digital audio (optical/coaxial), HDMI, RCA) will help me suggest potential problem areas.
Apr 21, 2015 | Audio Players & Recorders
No sound on 39 inch westing house
its not clear in the video if what kind of source (dvd, pc etc) did you hooked up in the tv. ok, the first thing you need to check will be the connection from the output jack of the source going to the component input of the tv. if you are using the 3 colored rca connector, the yellow must be connected to the video out of the source then the other end to the video input of the tv. the red and white must be plug to the audio output of the source then the other end at the audio input jack of the tv. then select the right component input settings in the tv like av, av2 , etc. making sure also your speaker set up in the tv is ON, then have proper volume adjustment in the tv.
Nov 18, 2012 | Televison & Video
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
Can't get sound to come from speakers with tv only the radio
You didn't give the brand and model of your TV, and I can't try to find a manual and see what kind of AV connections it has available. So here's some general information.
Many TV sets only have input jacks for external sources like DVD players or cable boxes. When you select an external source, or use the set's internal tuner for TV programming, the video and audio play through the TV. The trouble is that if the set has no audio output jacks, there's no way to get a sound signal out. The TV accepts only inputs
When the TV is part of a home theater system, most people use it just as a video monitor. All AV sources connect to the receiver, and audio is sent from there to the speakers. A video output from the receiver goes to the TV so you can see the picture, and the TV's speakers aren't used. If you have a cable box, FiOS set-top box or satellite receiver for your TV channels, they connect to the receiver too, since they're just another external source.
This doesn't work if you rely on the TV's internal tuner for TV channels, though. This might be the case, for instance, if you have a cable system where a converter box isn't required and your cable connects right to the TV. When you're watching regular TV, then, the sound comes through the set's internal speakers. If there's no audio output available on your TV, that's your only option.
As I said earlier, many TV's have only audio inputs. But some have audio output jacks as well, so the sound has a way out. If yours does, you can connect them to one of the inputs on the home theater receiver. Then when you select that input you'll get the TV sound through the speakers connected to the receiver. Depending on the design of the TV, you may need to leave the TV volume turned up. Some sets have outputs that are follow the TV's volume setting. On others, the output is an independent fixed level. Then you can turn the TV volume down and use just the receiver's speakers if you want.
Check the connections available on your TV and look for a set of "audio out" jacks. Your TV's owner's manual should have a section explaining how to connect it in different ways. If you need a copy, most manufacturers have manuals for download on their website.
Good luck with your sound, and thanks for using Fixya!
Jun 17, 2011 | RCA Audio Players & Recorders
Sound went out?
Unplug,replug the tv about an hour later.Let the tv to reset it self back to factory setting.Go in ur tv menu go to AUDIO setting.Go down to reset.Now ur tv should have sound back.No,sound after the reset.Than ur tv Tuner board is dead,require changing the Tuner board.
May 27, 2010 | Toshiba 32AV502U 31.5 in. LCD HDTV
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
Aug 09, 2009 | Samsung Theater System
My HD only works on my video setting, but I have no sound
Ok so the sound is fine on all of the other sources,
The component is running from the cable box to the amp, and you can see it.
just take the audio Red/Whit RCA out of the cable box, and input it to Cable/TV or whatever its labled, Red White, RCA.
If you want surround, then you will have to go Coaxial((single orange RCA) or TOS out of the cable box to the Digital input on the AMP. When you use this instead of Red White RCA, your amp will automatically switch between the different types of surround depending on what the source calls for or is encoded in.
You may have to get into the amps menu and change that amps input to Digital/Coax/TOS for the surround sound.
Any more specific questions, I need the model #s.
Jan 10, 2009 | Mitsubishi WD52527 52" Projection HDTV
Vga audio in
VGA does not provide sound, only video signal.
to get sound, you need to run a signal from the audio output of the computer (1/8" mini) to the audio in of the TV (RCA).
Sep 06, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Televison & Video Logo
60 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
