You shouldn't be breaking pins on either side.
Excessive debris in snow field?
Its designed to move snow, not frozen chunks of ice, nor tree branches, nor mulch, nor hockey pucks, nor concrete, nor...
if snow field is free of debris, then check for and remove foreign objects stuck in augers, such as wire, cable, rope, scarves.
If heaviy packed snow, slow down.
SOURCE: Left Front Brake not releasing so building
Sounds crazy but replace your brake line and see if that helps. I've had vehicles that do the same thing when there's a restriction in the brake line.
SOURCE: distributor camshaft gear keeps shearing
Replace the distributor.The weights have collapsed causing this to seize.Thats why now its shattered
SOURCE: Auger turning slow. Auger turns initially but
sure sounds like a shear pin, usually one end will be missing if it is broke. They are simple to replace but get one that is rated for your machine to avoid damage. Can you turn it freely without the engine running?? if so, it's the shear pin
SOURCE: My MTD 10hp auger will
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
