Question about Samsung Tab Tablets & eReaders
T590 runs and suddenly shuts code E00176001 appears what do I check?
No sound when im on web chat rca galilio tablet
1. Make sure the mic is not set to mute.
2. Check your battery charge. Low charge may turn off video.
3. Your operating system appears to be Marshmallow. I am not sure what application you are attempting to use for voice chat. It might be Google Duo, Facebook Messenger, Hangouts, or Imo, among others. If an application is not working, one generally tries reinstalling it.
4. Another application may be running and blocking use of the mic. Check what else is running. I think holding down the home button will reveal what is running. Shut down background apps and test the app you are using. Google Play may have What's App to check this.
Nov 28, 2017 | Tablets & eReaders
IPad air suddenly went black, except for a dim rotating circle of dots in the center of the screen. It is completely unresponsive. Know any fix we could do?
Put it on to charge. Press and hold the On button and the Home button until the white Apple logo appears and then let go. This is called a Soft Reset.
Dec 11, 2016 | Tablets & eReaders
Suddenly am unable to connect to internet
As for me...
I use the flash-light flip up control...
and BLUETOOTH... and my WAP both fall full victim to my larger than life finger tips...
CERTAINLY I'm just saying where I check first.
After that... go into settings
First.. check AIRPLANE MODE is "OFF"
Second check the WiFi is "ON"
Its all good... your INTERNET Service Provider IS DOING SOMETHING TO YOU... Give them a call
Jan 16, 2016 | Apple iPad Mini
If i reset my password will this get rid of multi-auth helper
No. Uninstall it from control panel and run an anti malware programme.
Feb 27, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
No Lock Screen & Device Options - Samsung Tab 10.1
sounds like a bug fault.
try a factory reset in the settings menu
Oct 16, 2013 | Samsung Galaxy Tab Tablet PC
My Ipad Mini keeps shutting off automatically, then turns back on. When the home screen is shown it just keeps glitching and shutting off. Whats wrong with it?
I would first try doing a hard reset. Hold the home and power button down simultaneously until the iPad completely turns off and the Apple logo appears. You can ignore the slide to turn off button when it appears.
If that doesn't solve the issue I would make an appointment with your local Apple Store and have the device checked out by an Apple Genius.
Hope that helps!
Mar 22, 2013 | Apple iPad Mini
Samsung tablet 7.0 will not turn on
Note: These steps clear data from the device. SD card data like your photos and music are not erased unless you choose to format the SD card.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Upuntil the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. PressHome to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
If you have access to the OS, you can also perform a hard reset in Settings.
1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
Sep 13, 2012 | Samsung Galaxy Tab Tablet PC
IPad shuts down itself
It seems that you've already tried reset (holding the home and power buttons, right?) the iPad and it does not work.
So you may need to connect your iPad to your computer and do a factory restore using iTunes.
Check this: http://support.apple.com/kb/HT1414
Jul 18, 2012 | Apple iPad 32 GB WiFi Tablet PC
My pen doesn't work on my tablet pc. It suddenly stopped working
Does your tablet have an LED to indicate it's being powered? If so, it must be the pen.
Does your pen have an internal battery? If so, it's time to replace it.
Aug 21, 2009 | Toshiba DIGITAL TABLET PC PEN FOR PORTEGE...
Tablets & eReaders Logo
50 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
