Question about Philips Pronto TSU3500 LCD Touchscreen Remote Control
Pronto docking station
Where can i bay one docking station for my pronto tsu 3000?tank youalessandro
  • jlicci Nov 29, 2007
    can i replace the bezel if cracked?
I have a tsu 3500 pronto. it works on the cradle, but not when removed? Any ideas?
I believe that's an older model, rechargeable batteries only last so many years. Seems as though they have given up. Replace batteries if you can. If not the Logitech Harmony Remotes are the best thing I have run across for universal ease. I have set up 5 for different clients and the start at about $50. I think you might be happy to switch to one.
Dec 30, 2014 | Philips Pronto TSU3500 Remote Control...
DSU9300 docking station not charging?
If you can measure the voltage from the charging unit to see if voltage is there, other possible reason and more common batteries are bad.
Dec 05, 2012 | Philips pronto universal home remote...
Docking station with known good SATA drive is not visible in My Computer
check the drive is visible to windows...
control panel>administrative tools>computer management>storage>disk management
it will list all drives (even ones you can't see in explorer)
assign it a drive letter and make it active from there.
May 10, 2012 | BYTECC T200U3 25_35 Black USB 30 Single...
Finding remote codes for Sony KDS-R70XBR2 television and Panasonic DMP-BD55 Blu-Ray player? Am trying to configure a Pronto TSU-9200 Universal Remote and their database does not show these components. -
Those two manual have the codes for each - United States - - United States - 6 hours ago -
I too have checked exhaustively apart from the info at these links above, It appears that you may have an incompatible remote. - United States - United States - › Forums - <<CHECK OUT -
Read up from that lot it will sort you out. Heaps of help and info Visit them ALL
Mar 28, 2010 | Universal Electronics Pronto TSU9200...
XB 3000 Completely unresponsive to Vista Ultimate
Yes that happens and you need to install the driver for it but make sure that you have Vista upgrades
If you need help with anyone then please let me know and I will help with it. Please do not forget to rate my service so we can improve on it with your help. God bless
Sep 30, 2009 | HP xb3000 (417329-001) Docking Station
Pronto TSU 3000 screen doesn't respond
This is probably due to a bad LCD connection, I just fixed a remote with the same problem
disassemble the unit, 4 screws on the back to remove the back cover, then one screw near the top inside to remove the circuit board. Pull off the blue edge bezel around the LCD (watch the clip on the right side near the hard buttons). Above the LCD is a Flexi cable with 4 pins- use a screwdrive or awl to make several indentations on those pads and then press down on each one for a second or two with a soldering iron
that cleared it right up for me...
Jun 24, 2009 | Philips Televison & Video
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Philips Pronto TSU3500 LCD Touchscreen Remote Control Logo
218 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
