Question about Samsung M2020W Xpress Wireless Black-and-White Laser Printer
WHERE IS THE WPS PIN ON SAMSUNG XPRESS M2020W
    Sergeant:
  • Samsung Expert
  • 360 Answers
It doesn't generate it's own pin. You need to connect the printer to the wifi with the PIN of the WPS function of your router.
or, just fill in the password, which always works.
Posted on Jan 23, 2019
  • frozen house
    frozen house Oct 10, 2019
    not sure what your saying
SOURCE:
How do I FIND WPS PIN ON SAMSUNG GALAXY TAB3
The pin should be on your router. log into the router to get the pin.
if you go to 192.168.1.1 or 192.168.0.1 you should get a login screen
Mar 22, 2018 | Samsung Tablets & eReaders
I have a Samsung LDM2020 wireless printer I’m trying to set up , but I don’t know the WPS PIN , I don’t have the booklet it came with or I don’t find it on the device, please help, it’s fairly new at least...
The WPS "key" , not PIN, is on a label on your router. Not on your printer.
Use that for setting up your printer. If you're leaching off a neighbors wifi system, you're out of luck.
Feb 05, 2018 | Samsung Computers & Internet
Where is the wps pin on a Samsung direct w8c48x printer
It relies on the WPS button on your router. Get to the Searching for WiFi on the printer then push WPS button on router. After a little delay the printer should say it has connected to network. If not, use the function that connects via the router password entered directly.
Good luck and please rate 4 stars if answer is helpful.
Oct 17, 2017 | Samsung Computers & Internet
I have a samsung printer M2070FW. I need a (WPS Pin) so i can hook up the printer. Where or how do i get this item
Go to the menu button on the printer (choose the option above "OK" button), choose "Network" (Get this option by keep pressing the Menu button until the "Network" option is shown and hit "OK")--"Network Configuration"--"Print". Page #2 of the printout will shown the WPS pin number of your printer. There are two WPS serial numbers shown, but the one on the bottom called "WPS-Pin for NFC" worked for me.
Mar 12, 2017 | Samsung Xpress M2070FW Multifunction...
Why won't it connect to wifi wireless laptop?
Dear
You can press WPS switch of the printer for a long time more than 10 secs. and search the wifi device in your laptop.
Before that its assumed that you have done the driver installed on your lap top using usb cable. If not, you may do the driver installtion using usb cable for 1st time and then disconnect the usb cable and install the driver by choosing wifi. before click next the wps switch of the printer to be pressed about 10 secs.)
Or you can follow the link to down load the driver and user manual.
Thanks.
Printer Support SAMSUNG India
Mar 14, 2015 | Samsung Xpress M2835DW Replaces M2625D /...
Get password for Samsung M2020W
Most likely lsu needs cleanup or replacemnet as very old model
Oct 13, 2014 | Samsung Office Equipment & Supplies
What is wps pin
Wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices.
WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either a button on the product or a an option on the wizard or utility screen.
Aug 15, 2014 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Wps pin wireless optical mouse
if i have mouse with usb dongle then no need to wps pin or if not then try 0000 or 1234 its default
Oct 31, 2013 | Microsoft Computers & Internet
Can't find the PIN of this product
Good morning. There is no PIN to find on the router. You get the PIN from the Wireless client and enter into the router setup screen.
The wireless router supports two types of WPS, the WPS via Push Button and WPS via PIN code. If you want to use the Push Button, you have to push a specific button on the wireless client or in the utility of the wireless client to start the WPS mode, and switch the wireless router to WPS mode. You can simply push the WPS button of the wireless router, or click the 'Start to Process' button in the web configuration interface. If you want to use the PIN code, you have to know the PIN code of the wireless client and switch it to WPS mode, then fill-in the PIN code of the wireless client through the web configuration interface of the wireless router.
Here is the link for the Owners Manual for your router..
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N3_UM.pdf
Hope this helps..
Nov 03, 2012 | Encore ENHWIN3 Wireless Router
Samsung M2020W Xpress Wireless Black-and-White Laser Printer Logo
4,101 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
