Question about Saeco Incanto Classic Espresso Machine
The coffee is comming out very slow (just drops). The display says to ventilate, but this doesn't help.
My machine is almost new ( 2 months). Recently the coffee has been comming out very slow, one or two drops at a time. Te display says to ventilate, and I have done that, but it doesn't seem to help. Any suggestions?
    Sergeant:
  • Saeco Expert
  • 223 Answers
  • Increase your grinder size.
  • Normally it is 8.
  • Make sure to only change the grinder setting while the grinder is spinning.
  • Change only two numbers at a time then make three cups to see the results.
Saeco Service center and parts warehouse
www.cerinicoffee.com
Posted on Nov 28, 2007
Saeco magic comfort display ventilate, what does that indicate
It means that no water is moving through the machine.. To reset, you need to hit the hot water button (that's the button with water drops). Let it run until the message goes away.
If nothing comes out then you need service. We can service this type of machine in New York.
http://www.cerinicoffee.com/espresso-parts/espresso-machine-service-center-new-york.html
Aug 11, 2013 | Coffee Makers & Espresso Machines
Coffe mashine is blocked
go to this link below for cleaning instructions and manuals, it may help hopefully. http://www.aabreecoffee.com/clean_maintain.cfm
Sep 27, 2007 | Coffee Makers & Espresso Machines
Gaggia Titanium - can't get it to move beyond 'Ventilate.' This started as a problem with extremely slow coffee output. We've been good about de-scaling but brought it into a repair place who cleaned it...
Select "Hot Water" and open the steam valve. Let it pump water out the steamer for awhile. It usually clears right away but may need to pump a lot of water to clear the error.
If you aren't able to get any water coming out the steam nozzle, you may need to prime the pump with the little squeezy tool they gave you with the machine - or you can use a turkey baster. Mainly you are trying to get water up into the pump to prime it (get the air out of the pump) so it can pump water instead air.
Oct 09, 2010 | Gaggia Titanium Espresso Machine
Ventilate message
Hi
Push the water button (the one with the drops) and that will clear the message. The pump slows to much and the flow meter doesn't spin fast enough, the computer thinks the pump is bad. If your coffee is taking too long to brew, then you grind is too fine. Move the lever to a larger #.
Jul 05, 2010 | Saeco Royal Professional Espresso Machine
Descaling cycle will not run
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Jun 12, 2010 | Gaggia Titanium Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
The coffee machines say ventilate
Hi
You need to run water through the wand to prime the machine. Push the button that has or says water or a drop. The display will say "hot water". When the "ventilate" disappears it will say "warming up". You are primed.
Oct 15, 2009 | Saeco Royal Professional Espresso Machine
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Kitchen ventilation not working efficiently
drop the unit down and check that it has a duct pipe the that goes to roof cavity or outside, and that the unit is net set to recirculate the air.
Jan 24, 2009 | Bosch Kitchen Ranges
Royal Professional machine
try to set the grinder to grind little more coarse, you have to make 2-3 cup to get the new settings to work.
To get off the ventilate you have to press the button for hot water and make a cup of water.
Hope this will help you.
/Mirran
Aug 11, 2008 | Saeco Royal Professional Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
152 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
