Question about HP LaserJet 4600dn Color Printer
HP 4600DN RED CARTRIDGE LEAKING TONER
I have a HP 4600DN leaking red toner . I have swapped out toner cartridges and still same result. I am not sure what to try next.
  • 4 Answers
Do the toner catridges leak from the same area? Does the leak occur immediatly after you replaced the catridge? If yes, then probably a bad cartridge also. Are these refilled catridges? If you remove the toner, tilt it to the right side and it spills then it is missing a seal.
There also was a problem with the D.C. controller for wich HP launched a replace during warranty period. The problem occurs if MP tray is set to any,any. This will cause the printer to initiate a cleaning cyle after each MP print causing too much waste toner to accumulate and eventually fill up and leak. For some reason Magenta caused most of these. So, if the toner spills occur after some time once a catridge was replaced this is the problem and the DC controller needs replacing.
Posted on Dec 15, 2007
  • HP Master
  • 1,113 Answers
Are you using non refilled genuine HP carts?
Posted on Nov 27, 2007
My hp priter is printing pink lines in the edges of my paper
Your magenta toner cartridge or magenta print cartridge is leaking ...you should replace it (magenta is the red one).
Mar 23, 2014 | HP LaserJet Office Equipment & Supplies
Printing blank page even in test mode. hplaserjet 1200
Checking the toner cartridge
Image formation defects are many times the result of problems in the toner cartridge. If there is any doubt, always replace the toner cartridge before troubleshooting image defects.
Use the following checklist to make sure that the toner cartridge is still operable.
" Make sure that the toner cartridge is seated properly.
" Inspect the toner cartridge for toner level.
" Check the expiration date stamped on the toner cartridge box.
" Check the toner cartridge to see if it has been disassembled or refilled.
" Inspect the toner cartridge to see if toner is leaking through worn seals.
" Check the surface of the photosensitive drum in the cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting
and image defects.
" Blurred areas on printed pages indicate that the photosensitive drum in the cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
Note A toner cartridge weighs approximately 863 grams (30.5 oz) when it is full, approximately 766 grams (27.0 oz) when it first fades, and approximately 742 grams (26.2 oz) when it is empty.
To redistribute toner in the cartridge
Before installing a new cartridge or when toner begins to run low, redistribute the toner by rotating the cartridge back and forth five or six times.
Jul 27, 2011 | HP LaserJet 1200 Printer
My hp laserjet m1005mfp printer is not printing document while i replace its cartridge twicely so give me solution urgently
Checking the print cartridge
Image-formation defects are frequently the result of problems in the print cartridge. If the source of the defect is not immediately evident, always replace the print cartridge before troubleshooting image defects.
Use the following checklist to make sure that the print cartridge is still operable.
? Make sure that the print cartridge is seated properly.
? Check the print cartridge to see if it has been disassembled or refilled.
? Inspect the print cartridge to see if toner is leaking through worn seals.
? Check the surface of the photosensitive drum in the cartridge to see if it has been damaged or
and image defects.
? Blurred areas on printed pages indicate that the photosensitive drum in the cartridge has been
To redistribute the toner in the print cartridge
Before installing a new print cartridge or when the toner begins to run low, redistribute the toner by
Jul 22, 2011 | HP LaserJet M1005 Printer
I have the 1522 printer. The toner ran out and I refilled using Chinese toner fron Deal Extreme. Black toner leaked out the right hand side of the toner cartridge messing up printing. I tried refilling...
it sounds like your priming station is full. you would have to spend some money to get it looked at this is not something you want to attempt your self.
Jul 30, 2017 | HP Office Equipment & Supplies
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 25, 2011 | Office Equipment & Supplies
My HP Laser Jet 4000TN printer makes a line along the right side of each sheet (about 2 inches in from the edge of the paper). How do I get rid of this?
3 possible options:
1 - Swap/ Replace the toner cartridge as it may be leaking
2 - the transfer roller may need to be replaced or cleaned(This is the roller you see once you remove the toner cartridge) easy way to tell is how much black toner you have in the bay of the machine where the toner cartridge sits
3 - the fuser needs to be replaced. IF the toner was leaking it can contaminate the fuser which will burn the black line into paper.
Oct 19, 2010 | HP Office Equipment & Supplies
Toner on the side of paper when copying
If you are using refilled toner cartridges then your toner cartridge may be leaking or the waste toner tank on the toner cartridge may be leaking. The other cause and more likely is the drum cartridge is leaking toner. I would recommend removing both cartridges. Then hold each 1 at a time over several sheets of clean white paper. Tap on the cartridges and see if any toner falls out of them. These cartridges are normally sealed and should not leak much if any toner. If toner falls out of either cartridge you will need to replace that cartridge.
Good Luck and Thank You for using Fixya.
Mar 27, 2010 | Sharp AL 1631 Copier
Ink spots on paper
If the spots are all one color, the toner cartridge of that color has a problem. Check the drum on that cartridge and make sure there are no bad spots on it. Your cartridge could be leaking toner.
Feb 27, 2009 | HP LaserJet 4600dn Color Printer
Red toner leaking onto "spongy" rollers and down onto the paper trays
Hi, its sounds like a faulty magenta cartridge. Contact your supplier for a replacement
May 13, 2008 | Ricoh Aficio CL2000N Laser Printer
False Toner message
Are you using genuine HP toners? If not HP puts a chip on there cartridges that tells the machine it is a new cartridge. Some generic toners do not replace this chip therefor giving you this false message.
Jun 21, 2007 | HP LaserJet 4600dn Color Printer
HP LaserJet 4600dn Color Printer Logo
767 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
