Question about Boston Acoustics MicroMedia Computer Speakers
Power indicator doesn't show power is available when plugged in
I've been using the subwoofer and speakers as an output device for my iPod. It just stopped working last week - when the unit is plugged in, the power light doesn't illuminate and there is no sound. Is there a fuse on the inside that I might have to replace?
    An expert who has answered 500 questions.
  • 620 Answers
HI, Jsprandel
There is no fuse inside, but, consider, a replacement, if you have warranty, but, unfortunally, there is no other way , beside take to a repair shop, and have it fix there.
you may have to secure your speakers with a UPS too, depending on the fluctuation on energy at home.
good luck
Posted on Nov 27, 2007
How should i connect my subwoofer- is it directly to the speakers or amplifier?t
I'm assuming that you are using a standard amplifier with L and R speaker outputs if a stereo Amp.... or L and R and SUB standard RCA output jacks. If it is a more complicated setup, having surround sound speaker jacks, then look for a SUB OUT jack or plug.
Some Subwoofers are self-powered, having their own, built in amplifier especially designed for that model. Sometimes they require a SUB connection and a power supply to the 110V AC house power too. These sometimes need a connection to a standard 3.5 mm HEADPHONE jack output plug. If it's this type, then the front of your amplifier could have one. Either way, the musical signal from amplifier to the subwoofer must be available on your Amp AND be received by the type of subwoofer you are using.
Mar 04, 2015 | Audio Players & Recorders
Subwoofer not working
The subwoofer is dependent on a sound amp powered by an external source whereby the speakers are powered by the line output from the sound source (like a computer speaker out jack). Powered Subwoofers controlled by a power amplifier require a power source such as an AC/DC source plugged into the house power. If the device is defective or a mismatch, the subwoofer will not function. Try a new power transformer and see if that fixes the problem. Other than that, if the power transformer is good, then the woofer could be defective.
Jan 13, 2014 | MA Audio MA5137 700 Watt 5.1 Home Theater...
Logitech Z5500 5.1 speaker system Hi, Any suggestions on how to troubleshoot this problem? there is no sound coming from the subwoofer or the speakers, but when I connect my mp3 player to the pod...
Try pulling the power from the unit for a few minutes, the reconnect. Make sure you've got the surround settings correct. If that doesn't do it, you've likely popped the amp or the amp's power supply in the sub box.
Jun 16, 2011 | Logitech Z-5500 Computer Speakers
Just moved and was disappointed to find that they my Creature speakers don't work from my MacBook Pro . Also don't work from ipod so it seems like a speaker issue? They have worked before on both...
It must be a power adapator problem. Most of the power adaptors do not have a indicator to show you if its working. Is the power indicator on the subwoofer module working if not I am right about the adaptor.
May 11, 2011 | JBL Creature III 2 Speakers
Speakers not working
Follow this checklist:
1) Make sure they're securely plugged into the wall
2) Make sure that any relevant power switches are in the "on" position. Is there one one the subwoofer?
3) Make sure they're securely plugged into your computer (or other device)
4) Make sure that the source device is actually outputting sound. Try plugging headphones directly into the computer
If these fail, please come back with more details. Are there any indicator lights/LEDs on the speakers? If so, do they light up when plugged in and turned on?
Mar 01, 2011 | Logitech X-540 Multimedia Surround Sound...
How do i connect my 5.1 speakers to my desktop computer
Know Your Speaker SystemGenerally in systems all the cables from the speakers are connected to the subwoofer which comes with a set of wires to connect, that includes : a power cord to connect the system to the AC outlet, a power connector to feed the subwoofer and the subwoofer wires. Your system should come with at least three set of cables for connecting your speaker system to your PC. These cables are usually colored to help with the installation.imageview-thumb.jpg
Start ConnectingYou should connect the cables matching the colors on the jacks located on the subwoofer. After connecting all these cable, its time to connect the rest of the cables like power, subwoofer and speakers. This is very easy if you pay attention to the subwoofer connection then you’d be able to follow the polarity that is written on the connectors. In the end, all your cables would be connected perfectly.
The above pic shows you all the ports to connect the wires to with all the color coded mannerism.
Knowing Your ComputerAll computers have atleast three connectors
  • Line-In.
  • Line-out.
  • Mic.
Computers with six channel audio systems have two more connectors, i.e
  • rear out.
  • center/subwoofer out.
You’ll need to make sure if you have these extra connecters by checking the back side of your computer.
If your computer doesn’t have these two extra outputs: rear out and center/subwoofer out, it’s a disadvantage, you’d be able to connect your 5.1 anyway but you would require to use the line in and mic-in plugs as an alternative. Of course there is a really big disadvantage in using this configuration: you cannot use your microphone or line in inputs and your 5.1 speaker system at the same time. This is the reason that you should buy a motherboard with 5.1 system built in.
Configuration Of Computers With 5.1 Supporting Motherboards
  • Front cable: To Line out.
  • Rear cable: To the Rear-Out
  • Center/Subwoofer cable : To Center/Subwoofer Out.
Configuration Of Computers Without 5.1 Supporting Motherboards
  • Front cable: To Line-out.
  • Rear cable: To Line in.
  • Center/Subwoofer cable: To Mic-in.
Software ConfigurationAfter every single connection has been made, its time to setup audio configuration in operating system. Since we had Realtec drivers on our PC, Double clicking it opened up Speaker Configuration tab. In various options you should select 6 channel mode for 5.1 speaker output and check Only surround-kit if your PC has the separated rear and center/subwoofer outputs and leave it if you don’t.
Now everything is done, you are completely ready to enjoy surround sound experience and don’t forget to leave comments if you find this post useful.
Apr 14, 2010 | Computers & Internet
SPL 10BV - no output after a long session with volume control seat 5 (12 o'clock). Has it got a fuse?
Most powered devices have a fuse. Does it work after being turned down in volume? or is it completely dead with no signs of power? or does it show some indicator light but no sound? Check for blown fuse and then for blown speaker coil.
Mar 03, 2010 | Velodyne SPL-1000 Subwoofer
Power in amp but no sound to speakers
you need to make sure youre getting a signal from the source, RCA's I suppose. Check for loose connections or broken wires. make sure to have 12v+ on power and remote inputs at amp...proper ground too. Lastly, check your ohm loads at speakers, maybe one is about dead. make sure crossover settings are correct.
good luck!
Sep 17, 2009 | Pyle BZDBP212 Car Subwoofer
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
Boston Acoustics MicroMedia Computer Speakers Logo
99 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
