Question about ASUS Intel 440BX Chipset P2B-S Motherboard
Ram memory upgrade not recognized in system info.
I installed a 512mb DDR 3200 400Mhz ram in my HP Pavillion and it's not being recognized by my system info. Why and/or how can I get it to show up in my system info.
    Champion:
  • 209 Answers
Does your mother board ddr2 compatible? do you have the manual of your motherboard? because there are brands listed in your manual which are compatible. if you have an existing ddr installed temporarily uninstall this and try this ddr2 512mb alone and let it run, if a beep beep sound occurs that means this is not compatible with your computer. remove this and bring this together with your ddr that work to your supplier, ideally the cast latency timer of these should be the same including the brand. hoping that this will help you
Posted on Dec 06, 2007
I have a Hp Pavilion 733b with chipset 845g, i have 1gb of ram but just recognise 256mb
Product: HP Pavilion 733b Desktop PC
http://h10025.www1.hp.com/ewfrf/wc/product?product=296502&lc=en&cc=us&dlc=en&lang=en&cc=us
Motherboard: FIC VG31
[ First International Computers ]
Motherboard specifications;
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07722&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=296502
Memory Type: DDR Sdram
Memory Speed: DDR Sdram at 266MegaHertz, or 200MHz
(PC2100, and PC1600, respectively)
Memory Sockets: Two. For Dual Inline Memory Module/s.
Maximum Memory: -> Maximum TOTAL Amount for motherboard.
2GB.
Maximum Amount for EACH ram memory slot: 1GB
So far looks good, BUT;
1) Is the Ram Memory Non-ECC?
http://en.wikipedia.org/wiki/ECC_memory
2) Un-Buffered? (Un-Registered)
http://en.wikipedia.org/wiki/Unbuffered_memory
3) Voltage: Does it use 2.5 Volts?
JEDEC standard for DDR Sdram ram memory voltage is 2.5 Volts (DC)
FIC is going to set the ram memory default voltage at 2.5 Volts.
Point? DDR Sdram at 2.6 Volts, or higher, may not work.
Betting the motherboard doesn't have SPD, and the ram memory may not either.
http://en.wikipedia.org/wiki/Serial_presence_detect
4) Ram Memory frequency rate:
What frequency rate of ram memory are you using?
(Excuse me,...'Speed')
The Intel 82845G Northbridge chip, will only support DDR Sdram at a -> Maximum <- frequency rate, of 266Megahertz. (266MHz),
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_chipsets
I have seen websites offering DDR Sdram at 400MHz for this board.
Maybe there is a BIOS update, I don't know. But going with the standard BIOS program that is installed, and info for the Intel 845G support, I would say this = No.
Processor Front Side Bus (FSB) support is either 400MHz, or 533MHz.
Ram memory typically operates at HALF of the Processor's FSB.
That would be 200MHz (PC1600), or 266MHz (PC2100), respectively.
[Half of 533 = 266.5
It's just rounded down to 266 ]
Can you read a manufacturer's label on the ram memory modules?
If so post what you see in a Comment.
Regards,
joecoolvette
[Sometimes when upgrading ram memory, it may take you to turn the computer completely off, and wait 1 minute. Then turn it on, and let it run for a couple of minutes, then turn it off. Wait 1 minute, turn it back on.
IF, the motherboard does have SPD, and IF, the Ram Memory has SPD, it may take a couple of 'Cold Boots', for BIOS to recognize the Ram Memory.
Some of the old mobo's were just like that.
{MOtherBOard ]
Jul 11, 2012 | Computers & Internet
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
RAM Slot does not recognize more than 512MB ( 184 )
Consider updating your motherboard bios.
http://www.asrock.com/mb/download.asp?Model=K7VT2&o=BIOS
Also make sure that your memory is correct for this system:
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
Jun 26, 2010 | Asrock K7VT2 Motherboard
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
I have got a compaq presario 6000 series pentium 4 desktop. I bought a 1GB kingston PC2100 DDR ram, 266Mhz ram for upgrade from my earlier 256MB ram. Somehow my desktop doesn't detect the memory upgrade...
the bios might be seeing it but windows might not, the possibility exists that windows is not able to view the full amount of ram installed try this. go to the start menu > accessories > system tools option and look for the system information tool, this will tell you more about the ram installed, note: windows dose on occasion report the wrong amount of ram when their is a 64 bit os installed or their is a 64 bit system
Dec 14, 2009 | Kingston 1GB PC2700 DDR DIMM Memory
Upgrading ram on laptop, new ram not recognized.
remove the bios battery for a few seconds...and place it back on ...this will make it see the new ram memory modules...if you are sure they are compatible ..they will work .....in fact ..the ddr1 333 512 M is more that compatible with your system and it will work after you remove the battery ...\ my recommendation is to reinstall a clean operation system after you boot up ...and format the C partition too...this have to be done after memory changes to get the max out of them ..
Nov 13, 2009 | Dell Inspiron 1100 Notebook
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
May 28, 2009 | Sony VAIO PCV-W300G PC Desktop
Memory upgrade not working
It only Accepts two PC–2100 SDRAM memory modules..If both are same then the slot might have some problem...
Jan 29, 2009 | Gateway 450ROG Notebook
ASUS Intel 440BX Chipset P2B-S Motherboard Logo
64 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
