My Ipod 3rd generation wont work other than when its pluged into my computer/or laptop by the charger. The second that i eject it and unplug it from the charger it instantly turns off. When replug it into the computer it will show the gray screen with the white apple symbol in the middle then automaticly turn into the "connected" screen...after charging it for over 6 hours it still does the same thing(unplug it and automaticly turns off)....ps:after unpluging it i try pressing the buttons like menu and center button at the same time it wont do anything...sorta like its frozen...just shows the black screen like its in sleep mode..yet when pluged, it works just fine and i can listen to all my music and stuff...so i know the keys arnt stuck...please help!
Your battery is most likely dead to the point where it can no longer hold a charge, which is the reason that when you unplug it from the computer, it dies instanly. Batteries are pretty cheap going up to about as high as $25 and if you get it done at a ipod place, installation should not be that much.
my nano is not workine circle , the screen is completely black now.Even i try to reset it by...
(More)
my nano is not workine circle , the screen is completely black now.Even i try to reset it by pressing the menu and the circle bottom that didnt even work!!!!!! so what do i do ??????
It holds a charge, even though the battery symbol doesn't pop up, and holding the Menu Button down...
(More)
It holds a charge, even though the battery symbol doesn't pop up, and holding the Menu Button down with Select just makes the screen go blank for a sec before the logo reappears. Letting the battery run out and recharging hasn't helped either. I'd love to know how to fix this... T_T
