Question about AudioBahn A2300HCT Car Audio Amplifier
Audiobahn A3200E Yellow light
I have a Audiobahn A3200E that was working fine until this past thanksgiving. I got in my truck and it just wasn't playing. The green light is still on but now the yellow light is on also. I have a red protection light that is not lite up. I don't know what the yellow light means but it has the letters THER above it. I need to know what the yellow light means and what could be causing it to turn on. I have sent this question to audionbahn with no answer. This is an old amp that was working very well until now.
  • evanbugger Nov 29, 2007
    Thanks for the help. I got an email back from Audiobahn that told me they think it has burn up something inside. Since they have not made this amp in years its going to be hard to find the replacment parts.
  • 631 Answers
THER likely means it thinks it's overheating (thermal protection). This is not a common failure.
Sometimes, low voltage can cause strange problems so you need to check the voltage on the B+ and remote terminals. Place the black meter lead on the ground terminal of the amplifier when checking the voltage. The voltage should remain above 11 volts. If it's below 11 volts on either the remote of B+ terminals, you need to trace down the problem. If the voltage remains above 11 volts, the amp probably has an internal fault and will have to be repaired.
Posted on Nov 26, 2007
  • Perry Babin Nov 29, 2007
    Most amplifiers use generic semiconductors and can be easily repaired. Amps that are 30+ years old can generally be repaired. Take it to a local repair shop that repairs car audio amplifiers. They should be able to repair it.
BOSS AUDIO SYSTEMS SE950 Car Audio Amplifier: I have a SE950 boss amp, hooked to 2 audiobahn 12"...
Sounds like you are over working this amp for sure.. Upgrading your power wire & battery might help, check your gain level on your amp to. This is not the volume for the amp. Its to get both amp and the cd player on the same page... And most of all if your subs are wired up to .5 ohm stable, see if your amp do the same... My answer to this ?? Upgrade your amp, Boss audio was never a good company to me, but that is my opinon. Audiobahn set up all the way..
May 16, 2010 | Boss AUDIO SYSTEMS SE950 Car Audio...
I have the audiobahn a1801q and it pulses like a slow heartbeat. everything is hooked up fine. anyone have an answer for me? o yea the red light above the power is on but the power light only comes on when...
The amp is gone. if you have checked and double checked and it is hooked up fine. then the amp is toast. Contact the manufacturer to get a replacement if its under warranty.
Apr 14, 2010 | AudioBahn A1801Q Car Audio Amplifier
A3200e wattage
Here are some specs:
  • 4800W Max, High-Current 2-Channel Car Amplifier
  • RMS Power Rating:
    • 300 watts x 2 chan. @ 4 ohms
    • 600 watts x 2 chan. @ 2 ohms
    • 1200 watts x 2 chan. @ 1 ohm
    • Bridged:
      • 600 watts x 1 chan. @ 4 ohms
      • 1200 watts x 1 chan. @ 2 ohms
      • 2400 watts x 1 chan. @ 1 ohm
  • Max Power Output: 4800 watts @ 1 ohm
  • this is the web site I got the specs from
  • http://www.sonicelectronix.com/item_61_Audiobahn+A2300HCT.html
  • Hope this Helps...
  • Jul 22, 2009 | AudioBahn A2300HCT Car Audio Amplifier
    Remote bass control short
    It Could be Eiher Problem Make Sure The Remote our using is thew same brand as the amp its plugged in to
    May 27, 2009 | AudioBahn A4002T Car Audio Amplifier
    Audiobahn A2301Q amp, charred RCA wires
    If the amp goes into protect with the wires unplugged from the board, the amp likely has more serious problems. It may have a shorted power transformer and almost certainly has shorted output transistors. If you think you may want to try to repair it yourself, read through the following page (particularly the information in the yellow box). Respond to this post if you have more questions.
    Basic Repair Primer
    Jun 08, 2008 | AudioBahn A2301Q Car Audio Amplifier
    Audiobahn AVM270Q (white out)
    You have to check if Video cable from Flip Down Monitor has RCA Plug Cable or Super VHS Plug Cable.
    RCA Plug is Yellow for Video= connected to Yellow Input of radio maybe loose.
    Get VCR or Video Camera and connect Video Output with cable to Yellow RCA Plug of Flip Down Monitor.
    Turn car on and VCR/Video Camera: you should get video to FL Monitor.
    If not, then FLM is defective or has adjustment problems..
    atdlee@netzero.com
    Mar 07, 2008 | AudioBahn AVM270Q 7in Widescreen Car...
    Power & protect
    my amp says Lo on the digital circle on top of the amp i have a mtx 9500 bridged to the amp and it cuts out at high volumes and suddenly please help
    Dec 21, 2006 | AudioBahn A8000V 400W x 1 Car Amplifier...
    Audiobahn A1500HCT in Protection Mode
    try just hooking up a power wire and ground wire only. disconnect your subs from your amp along with the remote wire and RCA's. if you have some jumper wires or run a wire from the power terminal to the remote wire. YOUR amp should come on, if it still stay's in protection mode it might be shot... hope this was helpful, i couldn get my a2300hcx to come on and tryed this and it came on turns out it was my remote wire was bad of the head unit...
    Nov 13, 2006 | AudioBahn A1500HCT Car Audio Amplifier
    AudioBahn A2300HCT Car Audio Amplifier Logo
    204 people viewed this question
    Top AudioBahn Car Audio & Video Experts
    Tygh Duval
    Tygh Duval
    Colin Stickland
    Colin Stickland
    Jerry Naidoo
    Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
