Question about Neff U1661 Double circotherm super Electric Oven
No heat in the main oven
The fan works but is only blowing out cold air in the main oven everything else works
  • nicita Jan 05, 2008
    fan is blowing cold aironly in main oven
Hi
We had the same problem - turned out to be the fan oven element - simple to fit - remove the back plate around the fan (6 screws) to expose the element. Remove screws securing element and disconnect wires (mark wires before removing) Our replacement was £40, but take the original as there are quite a few variants - you will also need the full ENR number (on side of housing) However, be aware that if this does not work, the thermostat may also have blown with the element. We were lucky as replacing the elelment fixed the problem.
Posted on May 09, 2008
The fan in main oven only blow out cold air
The fan does not produce hot air. It just circulates it. The thermostat turns on the heating element and the fan moves the hot air around. Unless you have an odd working machine. Baked bread for years an it only moves air for even heat.
Jan 31, 2015 | Ovens
Ec600 dodlm model the fan oven is only blowing cold air
check for blown oven fuse. replace heating element in the oven
Jan 30, 2015 | Ovens
Fan oven blowing cold
The fan inside an oven is usually for convection cooking. It circulates air that is already heated. It is not a heater.
Apr 29, 2014 | Candy Ovens
Hotpoint BD35 oven fan not working
The air you can hear blowing will be from the exterior cooling fan, and nothing to do with the main oven.
You need to check to seeif you have got a feed to the oven fan and element, the supply comes from the oven thermostat on the control panel.
Hope this helps.
Jan 15, 2010 | Ovens
Electric main oven fan blows out only cold air
For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Dec 07, 2009 | Neff Ovens
Cannon oven not working
If the fan is working o/k, then it is sure to be the oven element that is faulty, a common fault with fan ovens, replace element, and it should be o/k.
Please rate my soluti9on.
Thanks.
Jul 14, 2009 | Bosch HBL 5032 Electric Single Oven
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
Neff U1661 Double circotherm super Electric Oven Logo
260 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
