**UPDATE** Fixed. Found solution online on how to configure an automatic ENTER (CR) following these instructions... 'Start' > 'Settings' > 'System' > 'Intermec/Enterprise Settings' > 'Data Collection' > 'Internal Scanner' > 'Symbology Options' > 'Postamble' When the text field opens, fill with: \r or \x0D
SOURCE: Automatic RETURN/ENTER ...
I set scanner to defaults and had to Scan Bar Code labeled <DATA><SUFFIX 1> on page 4-50 of LS 2106 Product Reference Guide to set return after scan.
http://www.intermeccorp.com/pdf/2106setup.pdf
SOURCE: i want to my m2004 to enter barcode scan after each scan automati
Print Adobe pages 128 and 129 of 302 of the M2000 Series Product Reference Guide and scan the "Scan Options" "Data Suffix" and "Enter" barcodes. The scanner will give two beeps after the first barcode, two beeps after the second and a warble after the third programming (Enter) barcode.
The manual can be downloaded from this link: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969605apdf&sliceId=&dialogID=114420706&stateId=1%200%20114410949
SOURCE: Symbol P470 Enter key for field enter
This would be done with 123Scan. You would write an ADF rule with Keypad as the Code Type and then fill in the String and Starting at postion fields for your criteria. Action 1 would be Send Value, then select 7013 from the keycode box and click the green check mark.
I use an "A" so the user has to press the yellow Mode button and the 7 key to make the A. Then when they press the red Enter button an enter key is sent to the host.
If you are not familiar with 123Scan I would suggest contacting the Motorola helpdesk for further assistance. 800-653-5350
