-   My Hoover HNF3157-80 is really loud in spin - but the back bearing seems fine - any ideas?-   anne55
Dec 01, 2008
-   drum very noisy when spinning, i noticed when i emptied it that the drum has movement up and down when lifted from door entry point ! i gather i need new bearings ! Is this difficult to do myself?-   steveandfin
Oct 06, 2008
-   I have a Kenmore Laundrey Centre that is about 12 yrs. old. Over the years the most that went wrong with it was the dryer. I was able to fix everythime but now the washer is grinding during the spion cycle. I'm hearing that it could be a tub bearing and seal problem. Any other thoughts and is it worth fixing after 12 years.-   poregan
Jul 31, 2008
-   Real loud grinding noise when spinning. It stopped then started to smoke and smell. I took it apart and seen a barring that had been damaged. Doesn't balance when spinning. What part do i need to order
-   Guest
Feb 19, 2008
-   Grinding sound while agitating-   dottio
First day, I washed in five loads phew what a load! Next day, I washed 2 loads after that It went very loud like train between spin and extra rinse. Do you think it was water pump motor problem?
water is running out bottom. I took front panel off and see that water starts leaking during fill...
(More)
water is running out bottom. I took front panel off and see that water starts leaking during fill from bottom area of tub? What do you think is wrong?
My Model FTF2140FS1 Front Loading Washer just hums. The problem started when it got to spin cyclce....
(More)
My Model FTF2140FS1 Front Loading Washer just hums. The problem started when it got to spin cyclce. It didn't drain or start spin cycle. I canceled it out, reset it, drained it manually and tried restarting. Now all it does it hum.....
all of a sudden sounds real bad on final spin cycle. Also squeaky during slow wash. Checked floor level, seemed ok. Opened bottom and top and seems to be inside drum. Also found ~4 x3 inch of plastic mold that was part of outer shell of drum that had broken off. Next step will be to take off back cover and see if something is visible that seems to make drum off balance . Gentle cycle not as bad as othes but still way loud. Debating to call sears service, buy topend for 279 or see if I can fix. help!
Kenmore HE2 was initially so quiet you did not even know it was on...now, souns like something inside is grinding inside while spin cycle is running. I am hoping there is some simple fix...or to at least identify what may be causing this before I get totally ripped off by a repairman....;)
