Question about Poulan Pro Chain Saw 46cc 20"
No start problem Poulan Pro PP4218AVX
I ordered a ignition module after not seeing the spark plug fire but after playing with it found out it was the kill switch. Even before I was having a hard time starting it, After running for a while it would die and I would strugle to get it going again. I went to a shop and they told me to change the fuel and do the 40:1 mix I will try this and keep you posted
  • renemvalenci
    renemvalenci Aug 07, 2009
    CHEERS:
    This engine is certified to operate on unleaded
    gasoline. Before operation, gasoline
    must be mixed with a good quality synthetic
    2-cycle air-cooled engine oil designed to be
    mixed at a ratio of 40:1. Poulan/WEED
    EATER brand synthetic oil is recommended.
    A 40:1 ratio is obtained by mixing
    3.2 fluid ounces (95 ml) of oil with 1 gallon (4
    liters) of unleaded gasoline. Included with this
    saw is a 3.2 ounce (95ml) container of Poulan/
    WEED EATER brand synthetic oil. Pour the
    entire contents of this container into 1 gallon (4
    liters) of gasoline to achieve the proper fuel
    mixture. I went over the manual and I thought I had made the wrong mix ratio but according to it is 40:1 I was able to start and run it for a while and then died, kept pulling the cord until I had no more energy finally started and run again for 1 minute and then stopped, I can see the spark but no start again. I think it has a carburetor malfunction. Thank you
  • renemvalenci
    Thank you I will give a last try this weekend adjusting the carb. the way you mentioned. I will keep you posted. I was able to get a Electric Craftsman for free that works like a charm, only thing is manual oiling every 10 seconds and holding the knob for 3 seconds. Again thank you
    President:
  • 583 Answers
I own 4 saws corrently--- and i have had numerous saws over the years. i even had a business for 9years manufactureing lawn mowers and selling and servicing small motor s and chainsaws etc.------ and i would never use or allow to be used a fuel .oil ratiogreater than 25 to 1----- for what it is worth! but conditions here in aust may be different to usa
Posted on Aug 06, 2009
  • kerry littleton Aug 07, 2009
    thanks for the feedback.poulan are not abig seller in aust we probabley use predominately stihl . and they are 25.to 1 as are most saws here funilly enough mercury o/boards were 100 to 1 when they startedchanging things about 20 years ago but here in w.a they vrey soon brought it back to50 to1 it could be an atmosphere thing...the worst thing that can happen with the extra oil is the saw may smoke a bit and clog the spark arrestor gause occ asionally 1thing for sure, your problem is not mixture related from what you are saying i think yours is a carberation problem for sure..have you adjusted the H and L mixture screws? your manual sould tell you how. just in case they dont try this --screw the h screw in as far as it will go then back ir out 1 1/8 turns then the L screw in till it stops and back it out 1 turn (count the number of turn on each as you screw them in so you can always go back to where you started)if it starts and runs at max revsscrew the H screwin and out until the motor is as sweet as it wllrun then back off 1/8 th of aturn never go in more than 7/8 th of aturn... secondly do the ssame at idle,try that andsee how you go and thanks for the feedback
How come no spark?
I would change the plug first and check to see if the coil is firing by grounding out the plug and see if there is fire. If not the ignition coil or unit maybe bad. Hope this helps.
May 18, 2014 | Poulan Pro 25cc 2-Cycle Gas Blower...
I was using it one day cutting fire wood and it just died on me, i checked to see if it was getting any fire to it and it is not getting any fire to the spark plug, could someone help me find out what is...
Try a fresh spark plug first--gapped 0.020". If no help, remove the engine left side cover to expose the flywheel and ignition module. Turn the flywheel until the magnets are under the module poles, insert a thin business card into the pole gaps, loosen the screws holding the module, and let the module be drawn to the magnets. Tighten the screws and turn the flywheel somewhat to remove the card, then turn the flywheel one full turn to make sure the pole gaps don't close up further at any point. Remove the ignition switch connection at the body of the module (not the connection at the poles), then try for spark again. If still nothing, replace the ignition module using the above method. If you did get spark, return the switch connection to the module and try again. If nothing, check the switch circuit for being grounded at some point. Hope this helps!
Dec 01, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Poulan 295 model chainsaw/ won't start, no spark
Start first with a fresh spark plug set at 0.020" gap. Make sure ignition switch is on. If still nothing, remove the cover from the flywheel. Set the ignition module gap by using a thin business card between the module poles and the flywheel magnets. Loosen the mounting screws, let the module contact the magnets, and re-tighten the screws. Turn the flywheel to remove the card, then rotate the flywheel on full turn checking that the gap doesn't close-up any further. Check for spark again--if still nothing, remove the ignition switch wire from the ignition module. Check for spark--if spark now occurs, check the condition of the ignition switch or the connecting wire may be grounding out somewhere in between. If still nothing, replace the ignition module. Hope this helps!
Jun 10, 2010 | Poulan Pro Chain Saw 46cc 20"
Pro 42CC 2 Cycle Chainsaw, 18": how does this module work, what is the circutry ?"...
If you are speaking of the ignition module, the flywheel magnets induce a high voltage from an internal coil through a diode and into a capacitor and then the magnet position controls a transistor that discharges the capacitor into the ignition primary coil and that induces spark voltage into the ignition secondary coil which fires the plug. It requires several revolutions of the flywheel to charge the capacitor and why it takes several pulls of the starter to get the plug to fire regularly. That's a lot of action inside such a small package! Hope this helps!
May 18, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
No spark from spark plug
New Saw? Warranty time
Electronic ignition? Replace entire module. Pinched wire to metal case part for ignition switch. Permanently shorted ignition switch--replace.
Jun 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro Chain Saw 46cc 20" Logo
2,282 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Poulan Garden Expert? Answer questions, earn points and help others
