Question about HP Compaq nc6000 Notebook
Battery Light blinking and Laptop won't turn on
My charging/battery light is blinking but there is no display on the screen. Does not appear to be on???
  • cjnaka Dec 14, 2007
    My problem is similar but my charging light just goes on for a couple of seconds then goes off and the notebook does not start. Its like not getting any power?
Depends on how adventurous you wish to be !! Try pushing down on the area in middle of triangle formed by Bkspace, "K" and Ctrl key. Use a little more pressure than normal for regular key press. might boot back up. Not uncommon problem and sides divided as to fix. There appears to be a small chip on board under this area and it reacts to pressure. Weak solder joint apparently. Not a job for novice with a solder iron. Needs precise aim and temp.
Posted on Dec 12, 2007
This is a common problem with this model - push down ******* the top right corner of the keyboard for 5 seconds- where the delete key is located. then it should power up - if its covered under warranty hp will replace the motherboard
Posted on Mar 22, 2008
    Sergeant:
  • 324 Answers
Good morning, Mike!
OK! This could be a number of things. First, let's try something. Power down, remove the battery, remove the memory modules and replace just one module. Leave the battery out and try to power back up. If it works at that time, power down and replace the other module (if you have more than one) and battery and see if it works.
If not, get back to me with the results and we'll go from there.
Have an excellent day!
Ron-
Posted on Nov 26, 2007
  • Ron Roske Nov 26, 2007
    Mike,
    I saw your other posting on this problem and it looks like the things that I previously suggested didn't help. ;o(
    So, on to the next step. It's called "bard bones" and here is a writeup that I've done on the process. It takes a little time, but is a down and dirty approach that usually works.
    If you run into any problems doing this, let me know. That's what I'm here for! ;o)
    Ron-
    Reseat everything, or take it down to "bare
    bones" and see what happens.(Remove the battery and don't replace it until
    you are done with these processes)
    Reseating everything means to tear it down to the point that you can access
    every connector and removable component. Disconnect each cable, and component,
    one at a time and plug it back in. While you're doing this, check for water
    stains (mineral deposits) and gently clean them with alcohol if any are found.
    If it doesn't come up after doing this, try the bare bones approach.
    By bare bones, I mean to disassemble to the point that you only have the a/c
    adapter, motherboard, 1 stick of memory and the display hooked up. At this
    point, if it doesn't come up farther than it does at present, you more than likely
    have a bad motherboard.
    If it does show signs of life, start reconnecting one item at a time, and try
    to power up after replacing each item or connector. If you replace/reconnect
    something and it no longer does anything, you have just located the part that
    is bringing your system down.
    Using this approach, I have seen memory cards, hard disk drives, keyboards,
    mice, touchpads, floppies, cd readers all cause this type of problem.
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Laptop won't startup on power or battery
Step 1:
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. Unplug your laptop while it is running. If it still works, the battery has been charging. If it shuts off, or doesn't hold a charge very long, you have a bad battery. Unplug your laptop while it is off, then try to turn it on. If the battery is bad, your laptop probably won't turn on at all. Turn off your laptop's screen-saver when testing its battery. The screen-saver will conserve the battery and not give a clear time frame for how long your battery can really last. Click the battery icon on your laptop when it is unplugged. It can tell you how much battery life you have available. This icon is usually located in the bottom right corner of your screen and will provide the percentage of battery power you have left. Keep track of the time it takes to go from 100% charged to 1% charged. If this takes less than an hour, your battery is probably beginning to fail. You can also try this every week or two to see if your battery holds a charge for shorter periods. Factor in the amount of time you have used your laptop. Most laptop batteries last 2 to 3 years or about 500 charges. Wait a few days before determining whether a new laptop battery is faulty. New batteries sometimes take a few charges to build up to their maximum run time.
Feb 07, 2013 | ASUS F3SV-B2 Notebook
DS Lite screen won't light up
your battery is very low. Charge the battery for 3 hours. you can still play games, while it charges.
Jan 14, 2013 | Nintendo DS Lite Console
Battery? console has no charge when plugged into wall outlet I push power button blue LED comes on briefly , then red flashes 3 times, and the yellow LED lights up along with the health warning on the...
What color is the power light when the system shuts off?
    Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged.
    Blue: If the power light is blue when the system turns off, then there appears to be a problem with the system and it will need to be repaired.
    If the orange recharge indicator light blinks while the system is plugged in and charging, then it is likely that the battery is not installed properly.
    If you have ensured that the battery is installed properly but the orange light still blinks, check to make sure that the battery is a licensed by Nintendo. The only licensed Nintendo DSi battery will have the model number "TWL-003" (Nintendo DSi) or "UTL-003" (Nintendo DSi XL) and will display Nintendo's logo.
    Call 1-800-255-3700 if you still need help.
Jan 27, 2011 | Nintendo DSi Matte Blue Console
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Screen dont turn on.
Try with the battery disconnected from the laptop. This happens sometimes due to a bad battery or a bad battery charging circuit.
Jan 18, 2009 | Compaq Presario C700T Notebook
Blinking red light
What laptop brand and model is it? And where is the LED that blinks? Important details! Some laptops have a power light that blinks red while battery charges, then it turns steady green when battery is full. Some laptops have a red LED that lights whenever there is hard drive, CDrom, or floppy activity (read/write). This all depends on your laptop brand/model and where the LED is (side, near floppy/CD, top near screen, or on battery itself... so provide more details for me, please!
Nov 13, 2007 | Dell Latitude C640 Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
HP Compaq nc6000 Notebook Logo
4,002 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
