Question about Heavy Machinery
My bucket drops down. I can put the bucket down and lift the front end of Bobcat.but..the bucket will try to curl up. And stops.
  • 380 Answers
You are describing an oil leak in the control valve. Get this to a hydraulic repair shop.
Posted on Jan 22, 2019
SOURCE:
  • 582 Answers
SOURCE: Hydrolic arms wont lift up or down on Bobcat
CHECK ALL THE SAFTEY SWITCHES ON THE SAFTEY BAR . IF THE UNIT MOVES FORWARD AND BACKWARDS THE SWITCHES AREN'T THE PROBLEM
Posted on Aug 23, 2009
Testimonial: "The unit will move forward and backward. And the auxillary hydrolic switch works. I can also get front and back tilt, just no up and down."
braintrust
  • 62 Answers
SOURCE: bucket goes up but wont come down
sounds like check valve is stuck, could have some trash in your lines, check manuel and remove check valve and flush hydraulic lines. also accuator cylinder may be out, that would be at the lever, may not be letting the oil return
Posted on Oct 28, 2009
  • 31 Answers
SOURCE: hydrolic problem on bobcat
it may be broken
Posted on Jul 14, 2010
freetek
  • 5569 Answers
SOURCE: The hydraulic steel line on my 2010C bucket loader
Like other hydraulic systems, there is probably a procedure for bleeding the lines after loss of most of the fluid. You may still have air trapped in the system and once it works its way to the cylinder, the cylinder is working with air instead of fluid and the air compresses instead of doing work.
Posted on Sep 16, 2010
SOURCE: front end drops down nom wont raise up . air ride
dose anyone know where the sensor on 03 bmw x5 front suspension are located.
Posted on Sep 11, 2012
863 bobcat that drives but lift arms go up but will not come down? Also the bucket will open all the way but I'm unable close it? Any advice out there?
check the quick hose connections for the return lines
If they are not fully engaged and tightened up at the sleeve , the non return valve in each hose is not opened indicating your problem
Oct 09, 2018 | Bobcat Garden
How to remove bucket tilt cylinder on an 853 Bobcat skid loader
put the bucket on the ground and the tilt in a neutral position so that there is no load on the cylinder pins
turn off the engine
remove the hoses and cylinder pins
lift out
use plugs to control dirt from getting into the hose ends
Jul 26, 2018 | Heavy Machinery
How to remove front idler on bobcat 331 mini excavator
Bobcat 331 Mini Excavator, Front Idler Assembly
www.loaderpartssource.com/bobcat-331-mini-excavator-front-idler-asse...
Loader Parts Source, Inc. offers this Front Idler Assembly for Rubber Tracks (W/ Holes in idler) for replacement on the Bobcat 331 Mini Excavator. Serial Number ...
Bobcat Idler: Construction Equip Parts ' eBaywww.ebay.com/bhp/bobcat-idlereBayBobcat 325, 328, 331, and 334 Front Idler - Undercarriage, Mini Excavator, ... BobcatT140 T180 T190 T200 T250 T300 T320 T650 T630 T750 864 Front Idler ...Undercarriage Parts Can Help You:Eliminate Unwanted Machine Downtime.Front/Rear Idlers - Mini Excavator Partswww.miniexcavatorparts.com/productcart/pc/viewCategories.asp?...14Aftermarket front and rear idlers are available for Bobcat track loader and mini excavators, Kubota miini excavators, and ... Aftermarket Bobcat® Front Idler - Bobcat CTL ... Aftermarket Idler - Bobcat 325 328 331 334 430 335.
Dec 25, 2015 | Mini Cars & Trucks
How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Sep 23, 2015 | Toys
Machine was switched off at end of shift and key handed in as per procedure. machine was found this morning with bucket in down position with front wheels raised.
You have a ghost! or someone playing a prank. or someone trying to nick it, started it, pressed the wrong lever and lost their bottle.
Most of these keys can be replicated with a screw driver or even a nail so they are not very secure.
Aug 13, 2015 | Bobcat Garden
I have a bobcat s175 the bucket will not stay tilted up it slowly goes back down
Most likely a control valve is leaking. If it just comes down over a long period of time that is not unusual. Most all loader buckets will slowly drop when parked in raised position.
May 31, 2015 | Bobcat 773
Which is the best way to remove a 1990 toyota hi-ace van engine thru the top or drop it down ?
Try to lift up the whole bucket seats from the drivers side towards the right. Use the back seatbelt to hang the bucket seats. The engine is right inside the front row seats. That is where you can remove the engine thru drop it down..
Jun 29, 2011 | Toyota Passenger Cars & Trucks
Heavy Machinery Logo
73 people viewed this question
Top Heavy Machinery Experts
Moderator
Moderator
ray gallant
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
