Question about Toshiba RDXV60KB DVD Recorder/VCR - 320 GB HDD - 1080p - Black - Dolby
I bought a Toshiba RDXV60KB DVD/video, but when I press the button to insert disc, the panel door opens, but the disc bit won't slide out. Please could someone help me.
SOURCE:
jonags3
  • 83 Answers
SOURCE: Toshiba SD R2312 CD-RW/DVD-ROM
I have the same problem like you.one of the expert shared to me that my burner has faulted. I thing your problem is worse than mine cause I can still read cd rom vcd/ DVD files and movies. Just finfd new one that will give you quality output.
Posted on Oct 22, 2008
SOURCE: DVD PLAYER SAYS "INCORRECT DISC" AFTER "READING DISC"
LOCAL TV REPAIR SAYS THAT, WHEN THIS HAPPENS, THE DVD PLAYER NEEDS TO BE REPLACED AND WILL COST ABOUT $125 TO DO SO, WHICH IS NOT AN OPTION AS WE ONLY PAID $100 FOR THE WHOLE THING.
Posted on Jan 23, 2009
SOURCE: Door will not slide automatically; emits loud beeping noise
Something similar to that was happening with our Odyssey...the beeping when you are driving whether it's ongoing or intermittent is the "safety alarm" letting you know the door is not closed. The power lock is not engaging. What I do when I get the beeping while driving is hit the Door Close button. It causes the door to attempt to engage again. To fix it...we first cleaned out the space below the side running board (kids were hiding crayons and things in there), then looked for any obstructions along the top and bottom tracks. I sprayed a lubricant along the tracks (I'd suggest the dry lube kind...I used WD40 the 1st time and had streaks of it dripping down after driving), use a lube that has a long straw to spray in small places...and spray up into the track that runs the length of the middle of the car. Manually open and shut it a few times to get the tracks lubed, then try it out.
If you press the open OR close button by remote or in the car and get nothing...no movement/no noises/no beeping...then it could be the electrical circuit itself, the signal itself may be impeded...or the motor shot. Have you tried any of these suggestions before?
Posted on Mar 22, 2009
ABKSeeker
  • 69 Answers
SOURCE: how do you unlock the tray for the panasonic
Cannot eject disc. ≥The unit may have a problem. While the unit is off, press and hold (>> / >>I) and (< OPEN/CLOSE) on the main unit at the same time for about 5 seconds. Remove the disc . After disc removal or if this does not work you may need to reset to factory defaults. for the player alone.
To return all settings other than some settings to the factory preset.
≥Select “Yes” in “Restore Default Settings” in the Setup menu.
This returns all values in the Setup menu and the on-screen menu, except for “Remote Control Code”, “On-screen Language”, “IP Address/DNS Settings”, “Proxy Server Settings”, “Network Service”, “DVD-Video Ratings” and
“BD-Video Ratings” to the default settings.
If this does not work then you may need to reset everything to the factory settings.
To return to the factory preset. Everything Reset.
(No setting)
≥Reset the unit as follows:
1 Press [POWER] on the unit to turn off the unit.
2 Press and hold (>> / >>I) and press [POWER] and [< OPEN/CLOSE] on the unit at the same time for more than 5 seconds until “PLEASE WAIT” is displayed on the unit.
3 The power is turned on and then turned off automatically.
Cheers!
Posted on Feb 15, 2010
  • 24 Answers
SOURCE: i bought a dvd disc
Sometimes its 2 disks, one install disk and a play disk. if you have the install disk in your computer you can't play the game. if you dont have a play disk, you can download a crack here. Good luck!
Posted on Jun 10, 2011
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
Have a Toshiba RDXV60KB. Will play some prerecorded vhs vids but not others. It's as is the tracking is out. Can I manually adjust the tracking or is it back to the repairers.
Many if the unit has a vol or channel buttons those will when in play become manual tracking adjustments, it depends if they are there or not.
Dec 07, 2012 | Toshiba DVR660 DVD Recorder/VCR
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
It will not let me insert a disc and when I press the eject button, it sounds like it is going to eject a disc and then it makes a weird noise for 5 seconds. Then, it will say CLOSE for a bit. I got one...
It sounds like you have 2 disks stuck in there. TV repair shop, or try shaking the dvd player lightly while dvd is trying to open. You may need to help open the door, but too much effort could cause harm.
Jul 08, 2011 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Does not play when disc entered nor when play is selected. (XD-E500KB)
Hello
Push in the plug connected to the "Video Out" jack on the rear of the Dvd to ensure it is connected firmly. Check the connection at the back of the TV as well.
Press the "Source" or "Input" button on the TV remote to verify the television's input is set to the DVD connection.
Press the "open/close" button on the front of the DVD to open the disc tray. Insert and test different DVDs to determine if the problem is with a specific disc, or if the player will not operate.
Eject the DVD tray and insert the DVD laser lens cleaner. Close the tray and wait a few seconds for the cleaning disc to load. Press "Play" on the front control panel to spin the disc through the cleaning cycle.
Remove the cleaning disc, insert a DVD and test playback operation. If the machine still will not play discs, the main receiver unit may require internal repairs best left to an experienced technician.
THANK YOU FOR VISITING FIXYA
Feb 02, 2011 | Toshiba Televison & Video
Jan 21, 2009 | Toshiba M24F51 24 in. TV/VCR/DVD Combo
Copying video to dvd
1st, does it come with a driver...if it doesn't, just make sure it is installed properly in your PC, then you just need to install a dvd writing software in your PC e.g. NERO Pro (v7 or later)...then, all will fit in...
Jul 23, 2008 | Samsung DVD-R130 DVD Recorder
Help ejecting dvd
I had the same problem and tried for ages (even tried forcing the door open thinking I could just tape it shut) without luck.
Then my very clever wonderful husband had a go (I know i'm crawling and yes my knees hurt).
Any way to the relevant bit. If you hold the eject button down and at the same time slide a knife or similar object round the edge of the door where the screw is near where it says photo/select you'll find that the door opens as this is an override mechanism.
Feb 22, 2008 | Hitachi DZ-GX3200A DVD Camcorder
Disc Eject won't work after improperly inserting disc and since removing it.
I have an DZ-MV780 with the same problem. I found that the cover plate around the flash hot shoe only has a single screw. If you remove it and pull up the cover you gain access to the gear and lock mechanism. Hit eject and if necessary press on the white gears you see in front of the zoom switch. It should then cause the door mechanism to unlock and open.
Aug 24, 2006 | Hitachi DZ-MV580A DVD Camcorder
Toshiba RDXV60KB DVD Recorder/VCR - 320 GB HDD - 1080p - Black - Dolby Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
