Question about Samsung HLR5067WX 50" Rear Projection HDTV
How to change a ballast in a Samsung tv
Any insight into how to change the ballast?
    Sergeant:
  • 261 Answers
IT is a little tricky but if you have basic had tools and a philips screwdriver you should be ok. You have to remove back panel and then pull out LIght Engine to access everything. Some models it is possible to not remove light engine, but i think yours you do. Also you have to remove the lamp competely and remove the little screw that holds the ballast connector to the housing for where the lamp plugs into the male connector. Located on the back of where the lamp plugs into on the light engine. Usually there are 4 screws that hold the ballast in place and you can remove those as well. Also there is some black plastic cooling housing that may require to be removed as well to accomidate this. But keep in mind all connectors are keyed so you don't have to worry to much, it only goes back together one way. Samsung was very good about this when designing set. I may even have a ballast i could sell you at a lesser price then anyone out there. If you get it out, Let me know and we can go from there. Do you hear it trying to fire the lamp? I would listen for that first and if you hear any kind of zzzziiiiiipppp sound, then ballast is probably fine. Maybe lamp could still be bad. I have seen new ones quirky sometimes. Keep me posted and i hope this post was helpful for you.. Cheers...Guru Jay
Posted on Feb 08, 2008
Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Aug 02, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I changed the bulb of my Samsung tv and it is still blinking lamp. How do I fix it?
U here a alot of clikcking,turn power on to tv?Yes,than the Ballast board also dead,need it be replacing.The Ballast board,help to ignite the bulb.
Jun 20, 2010 | Samsung HCM4215W 42" Rear Projection...
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung SP50L6HX, I replaced the Lamp but still nothing.
Hi, Samsung haves a known issue with the ballast, once you make a replacement of the lamp, sometimes its harder to ignite a new lamp that has 100% of gas inside than igniting a old lamp that has maybe 60% or 50% of gas inside. Just in order to ignite the lamp, the ballast needs to send some High Pulses of Voltage, as high as 15 kV (that is the constant clicking sound that you are hearing). In order to resolve this you need to change the Ballast Board. I tried to look for your ballast with your TV Model # at samsungparts.com , but nothing showed up. You will need to find out which ballast part # you have in order to find it online. To locate the ballast part # please check the end of this video, you only need to take the lower back cover of TV off. http://www.youtube.com/watch?v=0jr_9A5Xd2Q
Here is a link of a ballast I found http://www.discount-merchant.com/SAMSUNG-9137-008-08905-Lamp-Ballast-Driver-p/1138231.htm?Click=49915
Dec 24, 2009 | Samsung SP50L6HX 50" DLP HDTV
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
My rca tv not working
the lamp which you rteplaced is not seated properly.and also it can be the problem of colour wheel or the ballast.to check out all three just check out this links 1 by 1 for colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
for lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
for ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Feb 09, 2009 | Toshiba 32AF41 32" TV
BALLAST
WARNING...The ballast can output 3000volts when it initially fires the lamp. Without the proper test equipment you could injure or even kill yourself. You've verified that the lamp is good and now suspect the ballast?
Apr 16, 2007 | LG 52SX4D 52" HDTV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
126 people viewed this question
Jerry Greenberg
Jerry Greenberg
