a
ansumana Posted on Jan 20, 2019
How can I set 3 decimal place after points on Casio se-s400
Setting places behind the decimal.
Question edited for clarity. It is 'decimal' not 'decibel' which is a measurement of noise levels.
It will show up to 9 decimal places. Page 3 of the manual refers
https://uwm.edu/libraries/wp-content/uploads/sites/59/2021/04/fx-300ESPLUS_2ndEdition_QSG.pdf
Can not set to give correct change casio se-3500
once all items are entered, press SUBTOTAL. Next, type the amount customer gives you (no decimal point). Then press cash and change will be displayed
It is rounding pi to 3
Sounds like you're in fixed point mode with 0 decimal places. To return to floating point, press FIX then . (decimal point)
3answers
How can i change the currency symbol on casio se-s10
Hi, how can I move the decimal point on Casio se-s3000? Example like now is 10.00, I want to move it to 1.000, thank you
1helpful
How do I round 991.5656641 three decimal places? I am using a casio fx-115es
Press SHIFT MODE 6 3 to set the display mode to Fix3. This will show all results with three digits to the right of the decimal point.
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
2helpful
My answers always come in fractions by default. how do i change the settings so they come in decimal points by default? further. how do i change the settings to have the answer in decimal points up to 4...
Press SHIFT MODE 2 to select the LineIO mode. To select the number of displayed digits in fixed decimal notation, press SHIFT MODE 6 and select the desired number of digits.
1helpful
Rounding off in Casio FC 200V
Press [SETUP] select FIX then press [EXE]. Enter the number of decimal digits you want (3 or 4). Press [ESC] then press [EXE]
Hope it helps.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
