Question about Electrolux Kitchen Ranges
I have Electrolux gas range model EW30GS65GS2 that has a fume smell when in use and water expels from top portion of stove grill. Can you help rectify this problem.
    Habit-Forming:
    New Friend:
  • 55 Answers
Since there are gas fumes this is a dangerous situation and should really have a professional with the right equipment to find the leak.
Posted on Feb 09, 2019
SOURCE:
Demy
  • 20 Answers
SOURCE: Magic Chef Gas Range
Does this oven glows before igniting the gas in the oven? if it does this unit uses a glow bar ignitor in the oven and spark module for the top burners.If it you dont see the spark( or hear the ticking sound the there will be no ignition. Do you smell gas even if there was no ignition happening? If there's gas that eliminate your gas regulator. If it's only one burner with spark but gas won't come on then your gas valve is deffective. But if there's gas and no spark ten it could be poor grounding, wiring, connection or switch or even spark module problem. You to need call your local Appliance service provider on this one. I do not recommend anyone fixing gas related problem if they are not a qualified servicer.
Posted on Aug 01, 2007
  • 833 Answers
SOURCE: stove smoke and fumes
Bebbie,
You didn't say exactly what it smells like but I assume it is not the smell of gas. This sounds like spillage of food into an area of the stove and the subsequent heating of it. Depending on which burner (or the oven) is involved, you're going to have to chase this down and clean it. Since there is minimal chance that this is electrical in nature, your other concern is a partially plugged burner caused by the mess.
Some notes: Be sure that any flame you do see has a predominantly blue appearance. If it is predominantly yellow, there is dirt which is restricting the air supply. This can cause carbon monoxide which is deadly.
Posted on Dec 03, 2007
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Posted on Dec 26, 2007
co7196
  • 3433 Answers
SOURCE: I'm smelling gas fumes outside my car. I can
vapor recovery system, should clear itself, some liquid fuel got into the vapor system. Avoid topping off the fuel tank.
Posted on Jul 11, 2009
  • 832 Answers
SOURCE: Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Posted on Sep 23, 2009
Kitchenaidksgst307.. oven set to 350...gets to 215 and stops...manye smell gas?? intermittent problem
Shut off gas immediately to stove and re check all line and fittings for possible leaks. Call gas company immediately if you even think you smell gas fumes....
Jul 14, 2016 | KitchenAid Kitchen Ranges
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
Gas fumes from maytag range
"The professional gas installer has been here several times to check the. Gas lines." Ask the professional gas installer to do a leakage test and inspect for a cracked gas line.
Jul 29, 2017 | Maytag 30" Self-Cleaning Slide-In Gas...
Cleaning the stove top.
Have you tried oven cleaner? Use the fumless type, otherwise yo will be overcome by the fumes. Clean the grill just like you would an outdoor BBQ, wire brush, the coat it with a light oil to prevent rusting.
Mar 31, 2010 | Thermador PD364GLBSS Dual Fuel (Electric...
Where can I find the make and model number of my Kenmore gas stove?
Usually down where you pull the drawer out below the oven door on a small business card size panel. If not check the back and on older stoves they can be under the top if the top raises up easily for cleaning.
Sep 21, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
Turn on the burner no flame oven have light but
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
thumbs up
Aug 17, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
OVEN PILOT WENT OUT
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Feb 14, 2009 | Tappan 24 in. Freestanding Gas Range...
Stove smoke and fumes
Bebbie,
Dec 02, 2007 | Frigidaire FGF378AC Gas Kitchen Range
Kitchen Ranges Logo
69 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
