A thought: The IntelliStation Z Pro 6221 comes equipped with either a Matrox or an nVidia graphics card. If your machine has the Matrox card, IBM reports a known issue which is exactly as you described and can be remidied by installing the 'lastest' Matrox driver from IBM (v. 5.75.02)
Hi..
Besure that the video card you inserted are correctly inserted you need to check it first. You need also to installed the vieo card driver. If the sam things occurs you need to disassemble the unit . Try to remove the proccessor and clean it after that insert it again. Check all the power cord and cable wire if it is correctly install in their respective port.
Thanks for using fixya..
Regards
ICmanServer
well the computer is my friends, the video card that is in there looks pretty new and its not the video card because i just bought a brand new one today to try but it doesn't work either. I pulled out the RAM and turned it on and there is no beeps, isn't there supposed to be??
How long ago did you put the video card in?? Electronics are notorious for going bad really quick. This is why they are so quick to warranty them if need be. Do you have another video card that you can swap back into it just to see if it is in fact not the video card?
