Question about Williams 2509612 Ceramic Mid-Size Heater
Pilot light on but heater won't come on when I turn up the thermostat
I'm wondering if it has something to do with the electric ignition. We've only had the heater a few months and it just stopped working this weekend. With our previous heater we were able to have heat even of the electricity went out.
Thanks for your help, Janice
  • 7 more comments
  • janicevilla Dec 07, 2007
    Thanks Buffalo12980,
    Our pilot has stayed lit this entire time but it is not igniting the heating element. We had a tech come out and look at it and he said it was a valve problem that would cost us $350. just in parts. We are looking ofr old receipts to see if we can return the heater for a new one as we have only had the heater a few months.
    Thanks again, I will pass this email on to my husband.
    Janice
  • janicevilla Jan 04, 2008
    We REALLY appreciate your help. We are going to try this today. Thank you! Janice
  • Anonymous Nov 29, 2008
    Thanks for the help, but telling me someone else has the same problem does not really help me at all.
  • nyj91302 Dec 17, 2008
    pilot light on but heater won't come on when I turn up the thermostat ,Please notify you when a new solution.
  • truecrow Dec 17, 2008
    i have the same problem
  • Anonymous Dec 20, 2008
    I don't see the switch.
    same
  • robbyt3 Jan 15, 2009
    Can you be more clear as to where that button is? If anyone had a picture that would be great.
  • robbyt3 May 11, 2010
    Can you be more specific as to the location of the button? If anyone had a picture that would be great.
Williams heaters have a manual reset for the spill safety switch. If the heater is not venting properly it will trip this switch and shut off main burner function. The switch is on the left side of the cover inside the small vent. You can use a screwdriver to push the button back in. If the heater then works you will need to get the vent inspected to make sure it is connected properly and there is no blockage.
Posted on Jan 03, 2008
  • 625 Answers
The heater obviously uses a standing pilot. in the pilot flame is a copper tube. this is a millivolt generator and is used to sense a lit pilot. it is a small dc generator that is connected to the pilot light valve. its function is to create a small voltage to energize a small electromagnet inside the main valve/pilot valve. when there is sufficient voltage present, it pulls in a magnet connected to a very small valve in the pilot gas line. this keeps the pilot valve open. when the flame sensor malfunctions you will get a pilot flame but when you release the button the flame goes out. replace the flame sensor and you should be back in business.
Posted on Dec 07, 2007
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
I have a Waterford gas log stove. The pilot light is on and working. The stove won't turn on either when it's called on by the thermostat or when I switch the stove to "on".
You have a bad thermostat is what sounds like when you turn it on yourself there is a electric valve that opens to make work and it is not getting the signal or you have something in the line feeding it.
Jan 29, 2013 | Heating & Cooling
Electrical problem
check ignition switch terminals and block connector...
Jan 09, 2013 | 2004 Yamaha V Star 1100 Classic
Furnace won't turn on
What is the make and model# of your Furnace? And is it a pilot light, or a hot surface Igniter?
Dec 29, 2012 | Heating & Cooling
Vulcan wall heater gas issues...
The igniter may be bad and needs replacing.
Jul 01, 2017 | Vulcan Heating & Cooling
GE (Rheem) SmartShield Water Heater. it rained on the hot water heater and now the pilot won't light. Any ideas?
Does it have an electric ignition? If so, remove the pilot light access panel, blow inside the chamber with a hair dryer. Do this until there is no more moisture inside. Then follow the lighting instructions. Try this even if it's a match start. Thanks and please rate.
Sep 05, 2011 | General Electric Water Heaters
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
My dishwasher stopped working, bought within the past few months, it seems like no power is getting to it. I've checked the breaker and all other appliances in house are fine.
Please provide make and model number of the dishwasher along with some indication of the last cycle it completed before this problem occured.
Aug 30, 2011 | Dishwashers
Williams 2509612 Ceramic Mid-Size Heater Logo
2,019 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
