SOURCE: sharp ar287 error code F2-00 what is the
Toner problem, most especially try to change destination of that toner being fixed on the machine
SOURCE: My boss has a Sharp AL-1655CS Copy Machine and it
Your problem on scanner unite.May be your copier is now lock position.
Solve:Unlock position.Left side under copy Board.Then solve your problem.Or study your copier user manual.
SOURCE: Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
SOURCE: My Neptune washer is showing error code dc..Once i...
See if my Clutch Fix post will get you started if your machine model type is a FAV6800A or FAV9800A.
Service Manual for reference. Sears Parts Direct for reference.
Your TDS is working or the machine would shake itself apart.
If you decide to DIY I will help you thru the process. If you decide to have it repaired show the Clutch Fix post to the repair tech it will help him help you back into service......Rich
SOURCE: whirlpool cabrio washer showing F51 error code
Hi Craig,
Just saw this post come up among F51 error codes (as it will show previously posted and answered questions ) and wanted to add some info I have regarding this exact issue you may or may not already have, no harm in posting either way.
The F51 typically indicates a failed "RPS" has been detecected...but it can be the result of other issues...just for future reference and if anyone has not come accross this before.
The scenario you describe is usually associated with a item stuck under the tub or a loose stator or a faulty "RPS" device or connection at the "RPS"...but I don't know if you checked that yet or if you know how, thus the error F51.
**The repair tip below is directly from Whirlpool**
F51 is usually associated with the rotor and stator/RPS assembly and quiet often it is initiated due to a loose rotor or bad RPS...I'd start by checking the bolt.
There is a repair tip regarding this which suggest checking the wires to the RPS and then the rotor, while insuring the center bolt is really tight via applying some "lock tight".
I actually see a lot of these and most times it's a loose rotor bolt, that is where I always start my diagnosis. Here's an exert from my files directly from Whirlpool...
You may want to check the rotor, I've seen the center bolt become extremely loose, thus causing the F51 error, this is where and what to look for shown below...
...but either way that should help out with the repairs and good luck.
Regards,
Macmarkus :)
