Is there a fix to un freeze the iphone7 and down load to other computer without iTunes involved? then reset & update?
SOURCE: I have Gateway 98 Windows
It appears that you are using Windows 98 as your operating system, if this is the case it is not compatible with the newer Ipod software. The new Ipod's require at least Windows XP service pack 2, Vista, or newest Mac software. Here is a link to Apple's website so you can check the system requirements in the support section. http://www.apple.com/support/
SOURCE: downloading music without itunes
Use Limewire.
I hope this helps. Please rate this solution.
SOURCE: Loading itunes
Simple fix:
For more info refer to pages 97, 104-5 & 111 of the user guide (also available from http://support.apple.com/manuals/#ipodtouch) and the knowledge base article here
All the best
Sean
PiDigital
SOURCE: how do you delete photos from ipad?
To delete photos in 1st generation ipad tap photos,tap photos again then tap photo you would like to remove.When in full mode trash can is available.
For 2nd generation and new ipad,tap photos then edit.Tap each photo to add check then tap delete to remove all checked at once.Please Rate
