SOURCE: Trips out the mains fuse.
must be an earth fault within the machine. suspect a burned out wire or switch. possibly carbon dust within the motor. take the top off the machine & have a look at the wireing loom. SWITCH THE POWER OFF FIRST
SOURCE: RE: Dell W4201C
i have a Dell W4201C ,the picture Dims or picture blinks when channel changes
SOURCE: RCD trips after different period of time
Sounds more like a fault developing as the cable heats up due to poor connections.trip operates about 30Ma ot .03 0f an amp which is a pest but good in its own right.If you referring to one socket then remove that socket and check for any loose burning leads,Check the fusebox again for any of the above, good idea to run an independant earth around 10 mm cable to main box just in case earthing is bad..hope you get on ok.
SOURCE: My washing machine it tripping the mains board
sounds like water is getting into the electrics....or your trip circuit has became week...try switching the trip switch from another circuit.
SOURCE: Power indicator /red/ and warning led/red/ are
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
