Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Solution on the left hand side the screen is like ditry patch ,you can see true it but it more visible on lighter backgound and it geting bigger by the time covering more area towards the right i have to keep it on higher brigthness so is not so visible ,screen is hung on wall one meter away from tall speakers, anything to do with that?
  • 231 Answers
If it affects all inputs including the MENU or OSD on tv .There is a good possiblity your set need a whole new LCD panel .The panel comes withe digital board that when going bad will display weird images on screen.It is not available on its own .It only comes with new LCD panel.If it affects only certain inputs then you have a (B) board bad on tv .So tv might need service in the furture..
Posted on Nov 29, 2007
Manual 883- rear tire almost rubbing on the right and run light not work left side -help
One possibility is the rear axle isn't aligned so the rear wheel/tire runs true to the axis of the frame. This can be visible with the drive belt not running true on it's sprocket, pulling to one side of the pulley, rather than being about equal spacing on each side of the belt to each side of the pulley.
The other possibility is the rear wheel was removed, and the axle spacers weren't reinstalled in the correct position(s).
The axle spacers are different lengths, and are specific as far as which one goes on the left, which one goes on the right.
May 22, 2013 | 2010 Harley Davidson XL 883L Sportster 883...
Print on left side of paper lighter than right side
Are you using a photo paper designed for printing on both sides? Most one sided photo paper is only meant to be printed on one side, and the other side is not designed to show true colors.
May 02, 2013 | Dell 1320c Laser Printer
Half the screen isa dark, left side
Most likely you have a faulty LCD panel tabs. This can be verified sometimes by turning set on and tapping or squeezing the top left side of the TV. The only true fix is to replace the panel. I've been told that Samsung may offer to replace the panel or give you a discount on a new TV. Samsung is know to have LCD panels with premature tab failure. So it may be worth while to contact Samsung and see what they can do for you. There are videos on youtube that show case the problems and show you how to patch the problem. just type in "LCD panel tab" in the youtube search box.
Feb 17, 2013 | Samsung LN46A550 LCD TV
When i turned my camera on I got a large image of a crack expanding from the lower right hand corner of the screen. Most of the screen is black and the cracks are lit up white. There is a blue patch of...
Sounds like a cracked screen. My Rebel t1i looked the same way when i dropped it a month ago. Not sure of cost to repair i never looked into it but probably not cheap.
Apr 08, 2011 | Canon PowerShot G9 Digital Camera
I have a white patch on th left hand side can
If you have access to a external monitor try connecting it to the laptop to see how it looks. If it looks normal then you most likely have a bad display.
Aug 07, 2009 | Computers & Internet
Flickering at bottom left hand corner of screen
Remove every Electromagnetic interference source in a 50 CM radius: speakers (low cost speakers are unshielded), fan, transformer, UPS.
Make a symple test using an AM radio: if you ear noise when approaching the area (screen Off) remove the source of interference.
Some time a different orientation of devices will fix the problem.
It worked for me
Jan 10, 2009 | LG Studioworks 700S 17" CRT Monitor
A split on a roland Juno-D Key-board 61 key
Pick Patch Mode
Pick patch e.g. Moog Lead
On the Eidt Section of buttons: Parameters (click once)
This should show on the orange screen
NAME : MG Lead 1
then navagate using the right left buttons to
Then press the split button (this is located on the right hand side of the board beside the ADSR pramaters) cick this until the light signifies that the board has been split aka the light beside the button is beside the word split
then navigate on the Orange screen to this
While on this screen press the upper/lower button on the right side of the synth.
this will then change the PATCHTONE (both) to PATCHTONE (upper) or PATCHTONE (lower) depending on what part you pick
then scroll through the tones you want for each part of the keyboard e.g. Tuba Left abd Trumpet right
Now what needs to be done is pick where the keys split e.g. C2 C3 C4 C5 or andy key on the keyboard not just the C's
Split point : C4
and then choose your split point
Now that youve finished you can save this setting for later playing. Navigate to:
pick your place on the keyboards memory I suggest one thats not already taken these are normally identified by this e.g. U00054
then click enter twice and you have yourself a nicely split keyboard! Enjoy!!!
Nov 20, 2007 | Computers & Internet
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
