SOURCE: Front air condition does not blow cold. Rear air condition does
sounds like a damper door in the front not working properly, these are actuated by the front temp control, the door is operated by either a manual cable, and electric actuator, or vacuum. I hope this helps you zero in on your problem. Merry Christmas
SOURCE: Blowing oil on an 8HP craftsman snowblower
That is a breather tube, I can't picture the motor off the top of my head but that tube is either connected to the valve cover or if the tube seems to go up over the motor then that tube goes down into the motor. If it's the one thats connected to the valve cover then it's possible there is to much oil in the valve box. If it's the one that seems to go up over the top and in then if your just alittle to much over full you'll get oil out of that tube cause that tube sits alittle above the oil level.If your oil level is right on the line then I would run it for a bit then check the oil level. If the level is still good then you should be ok but keep an eye on it if it continues to blow oil out I would take it in to get looked at futher.
SOURCE: '98 S-10 heater blowing cold air - not hot air
will the air flow switch from floor to the mid to defrost? if so then we have a problem with the tempature door actuator. easy to replace just in tight place. Keep me posted for more help or if this was any help thanks
SOURCE: Cold AC but weak Airflow---Also Driver side not as cold as passenger
The air doors are controlled by actuators that on of them or so may need replacing.
SOURCE: Front Blower
ok, missed the part about the rear ac working, the part that causes this is called the air temperature control blend door actuator motor, it is an electric motor driven gear drive that moves the plastic door inside the air ducking to mix or shut off the hot or cold air from the ac evaporator core or the heater core, you will need to replace it.
Testimonial: "Great thanks that could be my problem. Is the motor by the inside coil"
