Question about Jenn-Air JES9860 Electric Kitchen Range
Numbers The numbers 7,8,9,0 on the display panel do nothing when pushed (no beep, no number) everything else appears to be working. The oven can be set by using the other numbers and guessing or using auto set. Any idea what the problem might be? My wife is concerned that the problem will only get worse and other numbers will stop working. Is this highly likely or is the malfunction random? Thank you. Matt
This is the same problem I'm having with my Jenn-Air electronic touchpad. I see you posted on Nov 26, 2007, but don't see an answer. I just posted my problem today (Jan 2, 2008) and hope to get a response. I have in the past had to have something behind the touchpad replaced, for a different problem. I don't like these touchpads, and would rather have mechanical controls as I had on my other 2 Jenn-Air ranges. If your warranty is still good, call and get it taken care of before it gets expensive. Since I didn't have any more problems for a couple years I didn't continue to purchase Sears' warranty. Now will try to fix it myself. I think a $1500 machine should be better built. One thing I did read, not on this site, but elsewhere, was to be careful to not get any kind of liquid on the panel. How does one do that and keep the steam and splatter cleaned up?!!!
Posted on Jan 03, 2008
Microwave was beeping a single beep once in awhile now nothing happens but the clock still works
A lot of the time when that happens the touch pad is bad and may have a colappsed air pocket on a pad. ( it makes the unit think you are pushing a pad ) The only way to fix it is to replace it (the touch panel) . Did you see any numbers coming up in the display. Like if the 3 pad was bad and making it beep it may have been showing a 3 in the display,. Always possible it could be a bad main board. But most commonly I have found it to be the touch panel. Try to unplug it and then plug it back in and try to set the clock. when you do, try each number pad and see if they all work. See if any feel different.
Oct 17, 2017 | In Microwave Ovens
How do I unlock the touchpad of my Profile 2.0 Spacemaker Microwave Oven # JVM2070
calvin,
If you have access to where your microwave is plugged in, unplug it for a few minutes and then plug it back in. This will reset your contol panel. Then follow your book directions to reset the time on the clock. Hope this helps!
Nov 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
My Maytag oven was shut off when a breaker was tripped. We turned everything back on however the clock says " 5ab" and none of the buttons work to reset the clock. Without this function, we can't...
That is the sabbath feature, to get it or defeat it:
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Thanks for using Fixya, let me know.
Jan 06, 2011 | Maytag Ovens
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Nothing works, displays numbers 1 thru 4.
What you're describing sounds like a corrupted controller, or maybe there is some grease, etc. on the controller, maybe where the keypad plugs into the controller.
Can you post a video demonstrating what happens?
This sounds really odd!
Jul 19, 2008 | LG LMV1630ST Microwave Oven
Frozen Display
It may be that the internal firmware has become corrupt, or there is a fault on the main processor board, or with some other area that is effecting the system processor, and thus the system is not able to function properly.
Call the service rep for your microwave oven and bring it in for an estimate.
Jerry G.
Apr 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Casio Databank watch
The replacement battery may be defective.
Nov 08, 2017 | Casio E-DataBank DBC3101 Wrist Watch
Jenn-Air JES9860 Electric Kitchen Range Logo
122 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
