Question about RCA Televison & Video
Replaced a power board on rca model #led46c45rq it's different from the one I took off all the connectors fit powered up for a few secondss. is there a trouble shooting problem to solve it?
  • 25 Answers
Not familiar the above model but it sound that the new PSU is not compatible. See is there is voltages on the PUS board connectors and comppear with the old one.
Posted on Jan 17, 2019
SOURCE:
JetJedi221
  • 25 Answers
SOURCE: Dell E173FP temperature sensitive 17" monitor
No. The best way is to take off the rear panel and insulator cover. Look on the board for "p/n: xxxxxxx" for the exact part number. I've found this to be the best way to ensure the correct board.
Also, once you're inside, you could see how many CCFLs you have.
Posted on Jan 08, 2008
  • 4 Answers
SOURCE: Replacing PC Board on Raypak 2100 Model 185 - connector differs
Sorry, I don't have an answer for you, but please let me know what happens.
I am in the process of buying the new board (# 010253F, right?) It hasn't arrived yet, but I'm assuming I'll be in the same situation. BTW, I am replacing mine only because the LCD screen is totally blank. Everything else about it is ok.
Please let me know what you did. My email is sroche@tellink.net
Thanks in advance,
_Steve
Posted on Jun 22, 2009
SOURCE: Dell Dimension 5100 will not power up. Was
Have you checked your monitor? Try your monitor on another PC and check it is OK. Once you change the MB battery you effectively "Kill" the PC, as all the settings in the BIOS are removed and must be reprogrammed. You must enter the BIOS, and select "Default" setup and then reboot, you must do this regardless of what else is done first.(A bit hard when you can't see anything" You say... "tried different power switch and ribbon cable connector" (sic) exactly what "Ribbon cable/Power switch"? Anyway as said check monitor, if it is OK, we will proceed from there, then, you must check your video card, test it in another machine, if possible, to see if thats OK, if it is OK, then it is now likely that you may have a Mother board problem. If you can, try another Video card to see if you get Video on screen. see we need to establish "Known Good" items, once we know whats what, we can then go on. Now if any of these things tested are faulty, Monitor, Video card, obviously replace them, however IF they are NOT faulty, as related it may be the Motherboard, Remove the RAM, and see if anything is on screen? If yes, replace RAM, If still NO, then take any cards out, and check, if then OK, replace cards one by one until you get to the one that stops it, there is your problem, replace it. All we are trying to do is get anything on the screen, if we do, then you must redo the BIOS, as related before. Now if you get it going it still may not boot through to windows desktop, if this is the case, after you boot press F8 and select safe mode, when you get asked if you want safe mode or system restore, choose system restore and choose a date before you had a problem that should get you back. You just have to logically work through, until you find the faulty "bit" and replace it.
Posted on Feb 22, 2010
Testimonial: "Thanks for the confirmation!"
  • 6 Answers
SOURCE: 52" hdtv rca hd52w67
check that board where you replace the fuse on the back look very close at the transformer the big black one and check the soldering it is cracked resolder it and you should be ready to go.. just look very close they are smalllllll cracks need good light.. thats what i had on mine and works good..
Posted on Apr 17, 2010
Rca led46c45rq sound but no backlight. Replaced LED/Power supply board (RE6HG1301), still no change, flash, then black screen, but still have sound.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Feb 21, 2018 | RCA Televison & Video
How do I fix my RCA with a black screen.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 15, 2017 | RCA Televison & Video
LED46C45RQ. How do I override parental control?
You will need the TV remote control to reset, but here is the manufacturers User Guide download link with all the info you need:
RCA Television
Dec 16, 2015 | Televison & Video
My rca led46c45rq TV has no sound what can I do
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 13, 2015 | RCA Televison & Video
Rca led46c45rq screen goes black
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 04, 2014 | RCA LED46C45RQ 46" LED TV 1920x1080,...
RCA Projection TV : D52W27D Connector BP120 on Power Board ?
BP120 is not used in that model its simply a empty socket that board is used in other versions of the ITC222 chassis in which some use that plug . But your model doesnt use it. Check the fuse on the AC main board which is right next to where the power cord plugs into that board. If the fuse is blown its most likely the flyback and HOT which are causing the blown fuse. If the fuse is good then the deflection board will need replacement. www.tvrepairworld.com has replacement parts and circuit boards for that chassis and also free tech support is available.
Feb 23, 2012 | Televison & Video
RCA Model D52w19
One thing that comes to mind is the two main connectors on the power/deflection board. They have ribbon cable in them. If they are white in color. One of them plus the one on the convergence board that is the same size, needs to be replaced. If they are black they are good. Part number is 258686. If your serial number is between G13XXXXXX and G26XXXXXX this is a very good posibility.
Aug 04, 2008 | RCA HD52W58 52" TV
Televison & Video Logo
59 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
